05-30-2017, 10:02 AM | #21 |
Re: Who's running a Marvel/Schebler carb?
I also have one with the "accelerator pump" in the fuel bowl but have never had anyone explain or know what it was. I would love to hear an explanation, if anyone knows what that is and how it works. Jack
05-30-2017, 11:33 AM | #22 |
Am running one on my Speedster.........very seldom have to choke it to start the car.
05-30-2017, 01:09 PM | #23 |
I ran a Marvel for a time, but one time the float somehow stuck open, with disastrous, leaky, scary results. I now run a Tillotson.
05-30-2017, 02:38 PM | #24 |
Hey, theHIGHLANDER, look here:
https://www.fordbarn.com/forum/showth...ight=disection |
05-30-2017, 05:07 PM | #25 |
I have a Marvel on both my 31 slant T/S and on my 31 Roadster p/u. They both run better than the Tillotsons they replaced.
If you want a viton tip float needle valve they have them at Steiner Tractor. |
05-30-2017, 05:30 PM | #26 |
05-30-2017, 06:23 PM | #27 |
I have heard they were sold by Ford as replacements after Model B carbs and before the tillys
05-30-2017, 11:43 PM | #28 |
I've run one before and the car performed very well with it. I'm not sure if it's as fuel efficient as a Tillotson or Zenith but I remember the car having a lot of pep with it.
05-31-2017, 06:17 AM | #29 |
I am running a Marvel with the built in pump and so far I am very happy with it's performance. I also do not know how the pump functions except that when vacuum is applied to one spring it allows an opposing spring to open a valve in the bottom of bowl. Also be aware that the vinton tip from Steiner does not fit all Marvel model a carbs.
05-31-2017, 07:22 AM | #30 |
Sorry about the link, just look back through the previous posts regarding MS carburetors and you will find much information and photos about rebuilding.
06-01-2017, 07:32 AM | #31 |
06-03-2017, 06:37 PM | #32 |
If all mechanical is good, maybe the GAV seals may need some replacement. Renners has these and gaskets.
06-16-2017, 11:26 AM | #33 |
Well I have been running one of these carbs with the accelerator function and find a noticeable quicker pickup. Seems to have better acceleration and much smoother idle and operation. Of the 6 I purchased at a swap meet, this is the only one with the acceleration pump. I have rebuilt 3 others from the parts and tested them on my car, a 29 Tudor, and found them to operate well but not as well as they have a very small delay in acceleration. Will look for others at SMs. Talked with Renner's and they indicated this version was used by GM on older Chevrolets. Oops, did I put this on a Ford.
This one sets up just like a Till and Zenith, idle adjustment and GAV. Starts with GAV open 3/4 - 1 turn open and after warmed up it runs around town and road at 1/4 open. Spark plugs look great after a longer run. Waiting to get into the higher mountains to see if the 1/4 more closure will work at higher altitudes. I am running a 6.0 head, modified B cam with inserted bearing and 3.54 diff. This is sweet as it turns 2180 rpm at 55 mph. Looking forward to working out some MPG on a long trip. Using regular California gas, 10% alcohol. |
06-16-2017, 02:09 PM | #34 | |
Joe K
Shudda kept the horse. |
06-16-2017, 02:36 PM | #35 |
Were they als called Sears ?
"I can't cry as long as I know the Lord has risen " |
06-16-2017, 02:55 PM | #36 |
I just reported what I was told. I haven't seen a Chevrolet installation. I saw a Chevy version on the internet and it does not have the choke rod on it just a choke lever. No GAV adjustment. The one I have has the accel. pump and the Ford GAV and Choke but the fuel input is only for the A version, there is no B version input I have on all the others. Might have been an experimental version with the GM version as both top and bottom have parts for the accel. pump. Next time I have it off the car I will try to get some detailed pictures of it.
06-16-2017, 03:02 PM | #37 |
I have also heard them called "no name carb and "square-bowled carbs". Western auto sold them along with Firestone stores.
06-16-2017, 04:40 PM | #38 | |
Joe K
06-16-2017, 05:27 PM | #39 |
06-16-2017, 10:00 PM | #40 |
Photos of Carb installed and internals showing Accelerator valves. Note in Install photo there is not a forward fuel inlet for a B installation.
Photo 1.jpg Photo 2.jpg Photo 3.jpg |
