Old 06-02-2015, 03:37 PM   #21
V12Bill
V12Bill's Avatar
Default Re: Wheel nut torque ?
Uneven tightening of lugs on disc brake rotors has been known to cause warping of the rotors. Could possible do the same to a drum to say nothing of loosing a wheel at speed for being too loose.
V12Bill is offline   Reply With Quote
Old 06-02-2015, 03:41 PM   #22
sidevalve8ba
sidevalve8ba's Avatar
Originally Posted by scooder View Post
Tight, but not red face tight.
Martin.
Best one I've heard yet.
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 06-02-2015, 04:28 PM   #23
Mart
Mart's Avatar
Four white knuckles.
Mart is online now   Reply With Quote
Old 06-02-2015, 06:28 PM   #24
48 coupe
48 coupe's Avatar
half turn before they twist off.
48 coupe is offline   Reply With Quote
Old 06-03-2015, 10:57 AM   #25
Bruce Lancaster
"1949-1951 Ford per shop manual- 65-75#"
Go with a Ford spec like this if using a torque wrench. Ford used the same nuts and threads from '29---up into the 1970's (Model A's had capped acorn nuts, which changes nothing, all otheres entirely identical) on big cars and pickups.
If not using a torque wrench, use something fairly short like the original wrench that came with car to tighten, and keep something long like a breaker bar to loosen. If you reverse that you will have some bad moments next flat...
Bruce Lancaster is offline   Reply With Quote
Old 06-03-2015, 11:25 AM   #26
JSeery
JSeery's Avatar
Interesting thread, every nut/bolt/thread has a torque value but in most application they are never used! Wheel lug nuts would be one of them, I have never seen a lug nut set to torque value.
Old 06-03-2015, 11:46 AM   #27
Charlie Stephens
My local Costco does it. After tightening with an impact wrench they check it with a real torque wrench. Then they ask you to come back in 500 miles for a recheck. This, along with low price, is why I buy most of my tires there.
Charlie Stephens
Old 06-03-2015, 11:54 AM   #28
34PKUP
34PKUP's Avatar
Charlie Stephens
When is the last time you saw Costco do a 30's vintage Ford without aluminum wheels.
34PKUP is offline   Reply With Quote
Old 06-03-2015, 11:57 AM   #29
JSeery
JSeery's Avatar
It would be a good idea as how almost all of the tire places way over tighten lug nuts!
Old 06-03-2015, 12:01 PM   #30
51 MERC-CT
51 MERC-CT's Avatar
Yep' if Henry was worried about torque, with each car he would included a combination torque wrench, bumper jack handle, hub cap remover instead of the lug wrench, jack handle, hub cap remover.
Old 06-03-2015, 12:45 PM   #31
NealinCA
NealinCA's Avatar
I figure that I have to tighten all the lugnuts somehow. I have a click type torque wrench handy, so I always use it to tighten lugnuts...on all of my vehicles.
We had multiple people putting the wheels back on a pickup, one of the front wheels didn't get tightened and the hubcap was put back on. I drove the truck and ruined the front wheel. I just made it a habit to hear those 5 clicks on each wheel before I head down the road. Makes me sleep better at night...
Neal
NealinCA is offline   Reply With Quote
Old 06-03-2015, 03:41 PM   #32
V12Bill
V12Bill's Avatar
I once broke a 13/16" 1/2" drive socket using a 14" breaker bar to try to loosen a lug nut that a tire jockey had put on with an air wrench. Fortunately I was at home and not on the side of the road and got another socket and removed the rest of the lug nuts.
Old 06-04-2015, 07:24 AM   #33
jimalabam
jimalabam's Avatar
Great Comment Lawson...
jimalabam is offline   Reply With Quote
