Old 03-04-2015, 11:36 AM   #21
Brian T
Brian T's Avatar
Default Re: Early 28 shift knob
Originally Posted by Tom Wesenberg View Post
I bought a tranny once just because it had the mushroom knob on it. That's the knob I carefully wrapped with leather and tried to remove using a strap wrench. It wouldn't budge, so I sprayed some GIBBS on it and forgot about it for about 5 days. When I came back I unscrewed it with my hand. Wish all tight things would work that nice.
I found myself in the same situation except I didn't buy the trans, we tried to get the knob off with no luck, the seller was packing up his parts and I am sure he wouldn't have wanted much for the trans, oh well it got away,
---- BTW, --- what is GIBBS, ?.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 03-04-2015, 03:28 PM   #22
plind
plind's Avatar
Hi.
Here is a litle link , read about GIBBS OIL.. http://www.roadsters.com/gibbs/#intro
www.forda1927.dk
Tudor * A 2820 *
Town Sedan * A 4472283 * Orig.never restored.
plind is offline   Reply With Quote
Old 03-04-2015, 04:48 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Has anyone tried to make a mushroom knob from a round knob? It should be easy on a lathe as long as you have the profile.
Old 03-04-2015, 07:17 PM   #24
John Duden
John Duden's Avatar
I got a couple i can send ya if you want to try!!
John Duden is offline   Reply With Quote
Old 03-04-2015, 09:00 PM   #25
Tom Wesenberg
If you have a chipped one to send up with Shirley and Denny I could give it a try. I wouldn't want to cut a good one.
Old 03-04-2015, 10:45 PM   #26
Quigley1930
Quigley1930's Avatar
Why not just turn one from ebony
Quigley1930 is offline   Reply With Quote
Old 03-05-2015, 12:28 PM   #27
Gary in MN
Gary in MN's Avatar
Here are a few pictures of my attempt of making a " mushroom knob". I found the common "A" knob does not have enough size to be shaped into a mushroom knob.
I used a flathead V8 knob as a starting point, I borrowed a original mushroom knob from a fellow club member to copy.
A lathe will make this job a little easier, some work was done with lathe tools but most was accomplished with files and sandpaper. The finished knob is a little flat on the top end. By adding some body filler / epoxy you could add a little more crown to the top and match the original.
Gary in MN is offline   Reply With Quote
Old 03-05-2015, 01:25 PM   #28
CarlG
CarlG's Avatar
I still prefer the look and "feel" of the AA knob! Maybe that's because my first was an AA???
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-13-2015, 08:24 PM   #29
mrtexas
mrtexas's Avatar
Post a picture of an AA knob
mrtexas is offline   Reply With Quote
