#21 |
While we are on the budget is not a consideration, theoretical max power flathead subject, I have a question. Why don't any of the flathead Bonneville racers use a destroked 337 Lincoln motor in the flathead class (max 325 cubes)? Bigger ports, bigger intake valves, bigger main bearings, factory forged crank, huge oil pump volume, larger valve lifter diameter, etc. It looks to me like you could get a bit more power from one of these than out of a stretched to the limit Ford motor.
I know these things are heavy (I've got one), and a lot of parts would have to be custom made, but so what? Bonneville cars get weight added, and custom made parts is the norm for Bonneville flatheads. So why not the big Lincoln? |
#22 | |
#23 | |
Heres my ideas for the engine masters challange if the flathead was included. Start with a new French flathead block the exhaust dog bone issue has been eliminated. Next work towards a half inch valve lift actuated by rollers cam located in a tunnel flooded with oil the intake port shape issues would be greatly eliminated. Using a USA made crankshaft with five main bearings increase stroke to at least 4-1/2 inch. Next the rods would be of a beam type. Oiling changes including proper windage control and piston oil spray bars duplicating the latest technoligy used in any of the new factory high HP V-8's. Igntion crank trigered the spark plugs 3/4 reach with heat ranges adjustable for load required. Induction would be updated to a computer contoled system for the best air fuel ratios that allow HP and Torque gains. Combustion chamber design would follow the last design developed by Harley Davidson for their racing program in the sixtys. Thats where I would start not sure where I would end.
#24 | |
#25 |
Would that frog flathead be allowed in this engine masters thing? It does state American V8, 1954 or older, not including the hemi. A French engine built much later surely don't comply. I know they ain't allowed at Bonneville.
Martin. |
#26 |
#27 |
I can't understand how people call them "Ardun Flatheads". No, sorry, it's not a flathead anymore. Very cool and valuable, but not a flathead.
#28 |
I think the Ardun should be allowed because they were available at the time. What I meant was I don't think an Olds or Caddy should be able to use some modern interpretation of their heads in aluminum. I'd like to see how these old engines really compared. The Arduns were a true option and actually were part of the scene back in the day.
#29 | |
#30 |
I think you misunderstand me. In 1949 Edelbrock, Navarro and Ardun heads were available for the Flathead Ford. There were no Edelbrock, AFR or Dart heads available for any Olds, Caddy or Chevy V8 for that matter. I would like to see a comparison of what was available hot rodders back then. I would like to see just how good these various engines could be as they were utilized and raced in the 40's and 50's. Bolting today's technology onto a vintage block wouldn't be a fair comparison and wouldn't give a clear picture of the actual potential of the various engines as they stood back then.
#31 |
I'm late getting here because after reading the firs few threads, I didn'yt think it was a viable project. The OHV's are just too good. I was supprised to read about Ken Kloth's engine. Yes I was with John when we talked to him and was surprised he didn have the engine dynoed. I was impressed at his knowledge and the performance of the car And a very nice guy to boot. The best power I ever got from an engine on a dyno was 175 @ 4800. I was surprised at the amount as I wasn't after HP but torque. The engine in question was 284ci and was replacing a 258ci engine that went substantially faster. But it had never been dynoed. This was in a 1936 Hydroplane. Wish I had it back, them little fellows got power. Have no idea why we build big engines.
#32 | |
#33 |
Well, what you need is a flow bench. I made a home made one that worked quite well. I used it before I wrote my book and included the results. About 10 years later I had adigital flow bench given to me on loan, which proved my original flow system was very accurate in many cases. The down side of the flow benches is::: Uou get hooked on them looking for the HLY GRAIL of flow. Well after a year or so I couldn't find it. I did however discovered how I could increase the flow of a port in 15 minutes with a carbidr on a die grinder about 10%. But if you spend a few days in the same port, you're not going to get much more. Now if you could move the valves over the cylinder in a Hemispherical area with big valves and direct ports, you'd have something worth while. good luck.
#34 |
Okay, I know this is 'FordBarn', not 'FlatheadBarn', so excuse the following post
![]() Too bad they don't allow us vintage boys to run blowers - we'd give them a run with the FlatCad (or at least have some fun!): EngineBlowerDriveMockup4.jpg EngineBlowerDriveMockup101.jpg This is a 1940 Cadillac flathead engine, bored to 3.552 and stroked to 4.625 - about 366 cubes. Took us about 18 months to design/build the engine. Actually, if it was a flathead only class, then I would run the Flathead Cadillac engine, due to the factory port arrangement (all up top). This shows the heavily ported block and the intake/top-end girdle. IMG_0351 copy.jpg We've proven it can take some abuse and the EMC challenge doesn't care about weight, so it could be fun. The downside is that it is very expensive and time consuming to build these one-off engines - as everything is 'custom' . . . only the 'block' is stock in the end. But, we made 550 reliable HP on Gas and about 650 on Alky! We can't wait to get back to Bonneville this year . . . has been a long wait! B&S |
#35 |
I've always been impressed with what you guys have been able to do with these old "tank engines". I know the exhaust comes out the top of these engines (unlike Ford flatheads). It looks like the ports (from to back) are :
E-I-I-siamesed E-I-I-E. Looks a lot more efficient than a Ford. Those ports are relatively HUGE. I see how you think a blower would probably work well on these. |
#36 | |
I put about 120 hours into porting and relieving that block - as there are four different intake and four different exhaust designs . . . so your sphincter tends to pucker a lot more than on a flathead Ford!It does have far better breathing than any flathead Ford - unless you spend an insane amount of money on welding and Frankensteining the block (like FlatFire). Anyway, fun conversation in general. I do believe that a flathead has no chance to win this category if it has to go against OHV setups. Now, if we're allowed to put OHV conversions on our Flatheads, then things become a lot more equal. But, we have to remember the HP levels they are able to achieve with Chevy/GMC 6 cylinders with aftermarket heads - way more than we can achieve with even the FlatCad. Also, think about the first Olds Rocket engines - plenty of bad-ass combinations and later heads that can make a lot of HP. Yep - trying to compete with ANY flathead would be pretty much impossible (dollar for dollar, HP for HP). |
#37 |
#38 |
Don't ya just love grass-roots ingenuity? DD
#39 |
After seeing these last two examples, it would seem to me that running the exhaust out the top of the block would be a necessity for anyone wanting to make max HP from a flathead Ford. Does anyone know what they do with the conventional exhaust ports? Do they just run them as is, or are they plugged? Running them would give the exhaust a lot of places to go, but might mess up the flow characteristics.
BTW, the "spellchecker" on this site flags "flathead" as a potential misspelling whenever I post; has anyone else noticed this? Seems a little odd to me. |
#40 |
spell it Flathead (capitol F)
