01-22-2015, 03:38 PM | #21 |
Re: Auto trans for Model A
Seems like I remember that John LaVoy has an automatic transmission in his Roadster Pickup.
01-22-2015, 09:18 PM | #22 |
Contrary to all of the mis-information posted in this thread, the Chrysler 904 Automatic Slant 6 transmission works great in a Model A Ford. I have installed one, driven it, and sold the parts to others to do the same. It always amazes me , on this forumn, how so many people post replies to a good question, and have no idea what they are talking about.
When we were first asked to do that conversion several years back, I was sceptical about if the car had enough power, and if it would shift well, etc. So, we installed it. Not an easy task, as the car has to be 12 volt, have hydraulic brakes and you have to convert it to open driveshaft. All of these things are work, and we did them. We also installed 3.54 gears. The fellow we did this for had no use of his legs, so we also installed generic one size fits all hand controls, so it could be driven with no feet. These are made to fit any car, and can be removed in about 30 seconds for use in another car. You steer with your left hand, and use the lever in your right hand for the throttle and brake. We also installed a 5.5 Snyders head, Weber carb and alternator. Car drives perfect. Shifts perfect . Cruises at 65 MPH at 6000 feet. Art Moore in California has the parts made to adapt the trans to the engine. You must fab your own trans mount, and all the other parts to complete the job. If anyone wants to get these parts, just call me and I will give you Arts telephone number. Steve Becker Berts Model A Center |
01-22-2015, 09:41 PM | #23 |
Thanks Steve for posting this. This pretty much verifies what I was told by this old guy I met. He has no problems what so ever and swears by that trans. And now that you mention Art Moore, that rings a bell with who he told me made his adaptor also.
01-22-2015, 10:55 PM | #24 |
That news sounds good to me. Reminds me of an old Cliche' I like to use once in awhile "You can't Argue with Success"
I'm sure the extra compression and better carb help a lot with the drive ability. I've driven a car with Hand Controls before, you would be surprised at how well they function.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
01-23-2015, 03:20 AM | #25 | |
Some people have severe/serious maladies , but can keep driving a Model A because of innovators like Art Moore and his Mrs. Art is a FAST and 4E4 guy, if I remember correctly. And Art is physically challenged. It you hear/see his coupe go by, take a quick look because he makes great power from his engines. I met Art at Pomona car show/swap meet many years ago and he surely is a talented guy. Yeah, Chrysler 904 is what they all use behind A/B , seems like. Just coincidently, I just received an offer to buy one from a friend up north, whose health is failing. '29 roadster, with my old cragar head and 904 auto behind a warmed B ! Just scheming at where to get the $ from ! When you've had your legs worked over a few times, you will think more about ways as to how you can keep driving Model A. |
01-23-2015, 09:15 AM | #26 |
01-23-2015, 09:32 AM | #27 |
If you wanted to keep the A "reasonably stock" and it's a health issue, you could go this direction?
http://www.pmeautoconversions.com.au...ctronic-clutch http://www.mobility-aids.in/automati...ch-system.html Might present a different set of problems, but coulds be an consideration?
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
01-23-2015, 10:57 AM | #28 |
One hand control system has a lever like a column shift.
There are other setups that work differently. Two operations are needed to brake: 1. To brake you move the lever up in an arc to the 12 o'clock position this returns engine to idle. That is idle is at 12 'clock position and WOT is closer to 3 o'clock. 2. Then you push the lever "down" toward the steering gear to apply the brakes. 1 and 2 are needed so engine is at idle before you brake. I suggest using a handlebar motorcycle grip for the throttle, using two cables with a spring return. That way just release the grip, the spring rolls the throttle to an idle. Then you push the lever down toward the steering gear to apply the vacuum boosted brake. This makes for one less motion with the lever for braking. Last edited by Benson; 01-23-2015 at 11:03 AM. |
