Old 01-14-2015, 02:16 AM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Left turn much sharper than right turn
Here's the pitman arm and drag link on my 28 with a 7 tooth steering, and the wheels straight ahead.
Old 01-14-2015, 03:06 AM   #22
wensum
wensum's Avatar
I purchased an adjustable drag link from "Machine Girl" (a regular contributor to this forum) and it arrived in New Zealand in very short time.
It appears to be an excellent product and when I fitted it, I was be able to get full lock on both sides
Cheers,
Keith
wensum is offline   Reply With Quote
Old 01-14-2015, 03:38 AM   #23
Tom Wesenberg
Richard, look at the angle of my drag link, and notice that if I installed a shortened pitman arm, the arm would have to move rearward to connect the drag link. I'd guess you are using a shortened pitman arm, is that correct?
Old 01-14-2015, 06:29 AM   #24
Mitch//pa
pictures of the components would really help everyone
Old 01-14-2015, 02:20 PM   #25
Tom Wesenberg
I agree. A picture like mine and another picture of the left wheel steering arm would help to see the problem.
I've heard others say that installing the short pitman arm has caused the steering wheel to be a little off center, but it didn't seem like it was as much as this problem is.
Old 01-14-2015, 03:37 PM   #26
Richard Lorenz
Problem solved. Moving the contact between worm and sector by 1 tooth made everything fit and work properly. The Pitman arm angles slightly to the rear as Tom said it should when the wheels are straight.
I do have a shortened Pitman arm, about 5 inches center to center. The ends do not reach the locking nuts when fully turned. This is a penalty for having the shortened arm.
As to pictures, I certainly benefit when they are shown. Over the years I have tried to post pictures, but was not successful. I have copied a couple of different instructions on how to do it, so I will try again in the near (?) future.
Thanks again for you time and help. Richard Lorenz
Richard Lorenz is offline   Reply With Quote
Old 01-14-2015, 04:49 PM   #27
tbirdtbird
thanks for the answer. Purdy has said that the slight issues you may have with the short arm on the 7 tooth box are non-existent with the 2 tooth box
gives way easier steering either way
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-14-2015, 07:53 PM   #28
Ross/Kzoo
Ross/Kzoo's Avatar
Have you tried posting them lately? They are much easier to post post than before the major change to Fordbarn.
Ross/Kzoo is offline   Reply With Quote
