Old 01-05-2015, 12:24 PM   #21
d.j. moordigian
d.j. moordigian's Avatar
Default Re: Anti Rattler Pics
Originally Posted by Hoogah View Post
I agree that 29Cabriolet's service brake rod spring appears to be on backwards. Here's a photo of mine (RH side, taken from the rear). Pardon my pati..., er surface rust!
Also note that both springs attach to the front side of the bracket.
If the nut for the mounting bolt always goes against the springs (Mitch//pa), then mine is wrong way around?? Is there a practical reason for this (you can guess that I'm not into judging ).
This I consider incorrect, the return springs are pulling on the nut/bolt,..and not the tab.
Maybe Marco or Doug from the JSC will give us the answer?
d.j. moordigian is offline   Reply With Quote
Old 01-01-2016, 06:16 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
Dudley, you are correct that the springs should be on the other side of the bracket. The front springs should be mounted to the front side of the bracket and the rear springs should be mounted to the rear side of the bracket.
Old 02-11-2019, 11:39 AM   #23
37 Coupe
37 Coupe's Avatar
I did a search on anti-rattlers before I posted my question.What I need to know is where do the two front springs attach to? I think if it is a frame bracket mine are missing,possibly to make room for side mounts? Also I do not know for sure which ones to order for my not so late '31,no points car for sure.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 02-11-2019, 12:12 PM   #24
duke36
Should be a small angle bracket attached to the frame web directly to the rear of the sidemount bracket
duke36 is offline   Reply With Quote
Old 02-11-2019, 01:16 PM   #25
37 Coupe
37 Coupe's Avatar
Found them .Thank you.
Old 02-11-2019, 02:19 PM   #26
Werner
Werner's Avatar
Hello everybody,
the topic also concerns me because yesterday are in the attempt to adjust the spring leaves and make passable in the gliding, breaking the tired metal strips.
I also think that the follower wire springs (eg MAC's A2503BS) are the better ones like explained in the bulletin. They are also easier to change when tired.
But on the picture # 6 of Tom they look very different again. A homemade construction?
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 02-11-2019, 05:07 PM   #27
Synchro909
Synchro909's Avatar
I think it is misleading to refer to those springs as anti rattlers. While they serve that purpose, their main function, in my opinion, is to act as a return spring for the brake rod. I always install mine so that as you apply the brake (pull on the rod), the spring is tensioned. When the brake is released, the spring helps return the rod to the "at rest" position. Once that is considered, it becomes obvious which way they go.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 02-11-2019, 05:31 PM   #28
Werner
Werner's Avatar
Hello to Australia,
at first I also thought the "anti rattler" means that the push rods do not rattle. I now believe that these springs (retraction) should prevent thebrake pads "plucking" because they do not go all the way back to the rearmost position.
Werner
Citroen 11 CV, 1947
Old 02-11-2019, 06:19 PM   #29
Synchro909
Synchro909's Avatar
Originally Posted by Werner View Post
Hello to Australia,
Werner, I belive the springs serve two purposes - retraction and anti rattle. A very neat and economical (typical Ford) solution.
Old 02-13-2019, 04:32 PM   #30
ericr
ericr's Avatar
from what you guys are saying, the new repro flat type must be improved quality----ones years ago were junk with no spring to them, just a flat piece of metal.
ericr is offline   Reply With Quote
