Old 09-21-2010, 12:37 PM   #21
Model A Man
Model A Man's Avatar
Default Re: lower water outlet with a boss to tap for temp gauge
I was going to post pictures for you of where I drilled and tapped the upper outlet and where I mounted the guage but I can't remember how to post pictures. Sorry
Model A Man is offline   Reply With Quote
Old 09-21-2010, 02:39 PM   #22
steve s
steve s's Avatar
It's pretty easy--no need to mess with Photobucket or such. You need to get to the Reply to Thread screen where you compose your message. THen click on the the paper clip/attachments thingy up above the message box. THen follow your nose to upload a picture right from your computer; handles most any kind of file as long as they're not too big.
If you started out on the Quick Reply screen, you won't see the paperclip. Click on Go Advanced and it will appear.
Steve
steve s is offline   Reply With Quote
Old 09-21-2010, 10:00 PM   #23
Model A Man
thanks for the picture posting info. lets see if this works
Old 09-21-2010, 10:37 PM   #24
steve s
steve s's Avatar
Well, that sort of worked; I'm not sure how you did it. The images are supposed to enlarge when clicked on and then enlarge even more with a second click. Yours don't. I notice yours are called "attached images" whereas mine are called "attached thumbnails", which must have something to do with it. Dunno.
Steve
