Old 09-19-2014, 05:00 PM   #21
fordscript
fordscript's Avatar
Default Re: allen syncrograph / 37 ford
Do you have the proper length rod from the throttle shaft to the accelerator pump? Which connection S or W? Try running the engine with the rod disconnected, and the accelerator pump at the top of its stroke. This might reveal something.
fordscript is offline   Reply With Quote
Old 09-19-2014, 10:07 PM   #22
37SLANTY
I will test that out. It's on summer right now. I'm not sure what the correct length is supposed to be. Any one know?
An update to my earlier posts, engine runs much better now since setting the timing and tightening the manifold bolts. I suspect the big problem was the manifold sucking air under high vacuum at idle, but that theory will be tested tomorrow when I take it to the sniffer. I can now idle at 400 rpm easily.
Also I disconnected the vacuum brake and plugged the intake because that constant vacuum leak doesn't seem right to me. I know people say that's how it is, but I think any vacuum leak is a bad thing.
My distributor metal slider tab is set 1 line advanced (up in my case) from center which provided exactly 4 degrees advance at idle confirmed by my dial timing light, and my newly added TDC line on my crank pulley.
Road test engine is a lot more responsive and peppy. now we shall see what happens tomorrow at the test...fingers crossed.
37SLANTY is offline   Reply With Quote
Old 09-20-2014, 04:02 PM   #23
37SLANTY
Passed sniffer today HC was 337 instead of 2000 on idle test.
My driving test CO was higher than it was before for some reason, but still within range of passing.
Guess the intake bolts were the problem. The over advanced distributor probably didn't help. Thanks to everyone for their help and suggestions. I would never have suspected the intake manifold bolts were loose.
Still would like to know how to make the Allen distributor machine work with the positive ground pertronix distributor, but I guess I will have to keep searching for that answer.
Old 09-20-2014, 04:49 PM   #24
Don
Don's Avatar
A 6 volt lantern battery will not run the Allen machine,needs a 6 volt car battery,not enough amps in a lantern battery.
DON P
Don is offline   Reply With Quote
Old 09-20-2014, 06:40 PM   #25
37SLANTY
ok. You mean run the pertronix, not the distributor machine right? because if I test a 12 volt distributor I don't need a battery at all with the machine, the strobe works as is.
Old 09-20-2014, 07:06 PM   #26
Don
Don's Avatar
My Allen takes a car battery to make the Meters work and the strobe flash ,my Allen has a coil and set up just like a car
DON P
Old 09-20-2014, 07:18 PM   #27
37SLANTY
oh, ok mine does not. It works all by itself somehow. It must have a power supply in it.
