Old 06-04-2014, 05:48 PM   #21
36tudordeluxe
36tudordeluxe's Avatar
Default Re: 276 flathead test drive big improvement.........but?
Originally Posted by 51 MERC-CT View Post
At this point all mention of cam and cam duration are meaningless.
Perhaps the proper adjustment of the idle mixture screws will bring it closer to where it should be.
Have adjusted idle mixture screws to a lean setting as described by Edelbrock. Out looking for a timing light to help solve the problem, the one I have is outdated and missing the spark plug adapter.
36tudordeluxe is offline   Reply With Quote
Old 06-04-2014, 06:13 PM   #22
51 MERC-CT
51 MERC-CT's Avatar
Now that you have set to a lean setting and it is running, adjust for best vacuum and idle.
If the spark plug adapter is what I think it is, it's nothing more than a metal conductor that fits between the plug and plug wire to provide a spot to clamp the sensor. (nothing fancy and probably can be made up out of available materials.)
Old 06-04-2014, 06:19 PM   #23
36tudordeluxe
Have ordered timing light from Amazon, won't be here until the 10th. By adjusting do you mean rotating the distributor?
Old 06-04-2014, 06:25 PM   #24
51 MERC-CT
51 MERC-CT's Avatar
By adjusting, I mean the IDLE MIXTURE SCREWS
Old 06-04-2014, 06:56 PM   #25
Talkwrench
Talkwrench's Avatar
Don't take what Jack said to heart Im sure he didn't mean it.. The dial back light is a handy tool, but learn how to use the vacuum gauge in the meantime. I'd help you out but I wont be in Vegas for another 4 weeks [and counting wooooh!]
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 06-04-2014, 06:56 PM   #26
B-O-B
B-O-B's Avatar
Go to auto zone & they wil loan you one. You pay for it then when you are done you return it for your money back. Better than waiting till the 10th.
B-O-B is offline   Reply With Quote
Old 06-04-2014, 07:11 PM   #27
RandyZ
I have a 276 with the L-100 cam and it idles about 14" vac.
RandyZ is offline   Reply With Quote
Old 06-04-2014, 07:43 PM   #28
40cpe
40cpe's Avatar
Randy, approximately what is the idle RPM?
40cpe is offline   Reply With Quote
Old 06-04-2014, 08:01 PM   #29
billwill
Use a paper clipgoodluck
billwill is offline   Reply With Quote
Old 06-04-2014, 08:12 PM   #30
36tudordeluxe
Battery (OPTIMA) won't hold a charge now so didn't get a chance to adjust idle mixture screws for optimal vacuum reading. Was getting 10-11 vacuum HG at 850 RPM. Renting the light was something I didn't think of but like I say won't turn over now and quite honestly my frustration level is such that I need to move on to something else. Going to start hanging some of the front sheet metal while I've got someone to help me. Monday am leaving for a couple of weeks at the beach.
Old 06-04-2014, 08:15 PM   #31
40cpe
40cpe's Avatar
deleted duplicate post
Old 06-04-2014, 10:39 PM   #32
Ol' Ron
Ol' Ron's Avatar
I got my post mixed up, thought he was running a 59a engine. Getting old.
Old 06-05-2014, 12:24 AM   #33
36tudordeluxe
Ol' Ron knew what you meant; I've got the original 8BA distributor along with the one you machined for me.
Old 06-05-2014, 07:46 AM   #34
Ol' Ron
Ol' Ron's Avatar
I didn't know I did that? When?
Old 06-05-2014, 09:12 AM   #35
Richard in Florida
Richard in Florida's Avatar
Not to worry, Ron. I did it.
Richard in Florida is offline   Reply With Quote
Old 06-05-2014, 10:48 AM   #36
36tudordeluxe
Ol' Ron sorry about the mix up on the distributor, got my wires crossed again!
