Old 05-08-2014, 03:45 PM   #21
gavin m
gavin m's Avatar
Default Re: Twin plug Heads
There is. Pete took a couple of stock front covers, cut them about, then welded them up to make the twin dizzy's work.
Once the HAMB is back up and running I will post a link to the tech feature he posted.
gavin m is offline   Reply With Quote
Old 05-09-2014, 04:27 PM   #22
CrazyBackyardBuilder
CrazyBackyardBuilder's Avatar
I have this photo of a custom Twin plug setup,
CrazyBackyardBuilder is offline   Reply With Quote
Old 06-07-2015, 05:28 PM   #23
Scott G
Any other options available currently? I have seen Elco and Hogans.
Scott G is offline   Reply With Quote
Old 06-08-2015, 02:01 AM   #24
27lizzie
013 (3).jpgThis is my neighbors twin plug heads of his own design and his own twin dist. set up that he milled out of a block pf stainless
27lizzie is offline   Reply With Quote
Old 06-08-2015, 05:27 AM   #25
47Merc
Interesting that Flat Attack Racing are using single plug heads in their current twin engine streamliner where as they used to use twin plug heads in the earlier cars.
Their new SOHC heads should be interesting to see.
http://www.flatattackracing.com/
47Merc is offline   Reply With Quote
Old 06-08-2015, 10:24 AM   #26
Ol' Ron
Ol' Ron's Avatar
I think combustion theory is a very complicated subject. In aircraft engines the twin plugs are a safety fetcher, however, the added plug does add power. You can see that during runup. One component of the combustion cycle is called the flame front and begins the moment the plug fires. It runs across the combustion chamber at a rapid pace causing a spike in cylinder pressure as it travels. In some cases the pressure build up is so hi that some unburnt AF mixture detonated. What we call spark knock. The use of twing plugs can eliminate this with well placed plugs by shortening the flame front distance. Thus the logical place to put it is at the top and center of the chamber or over the piston and transfer area.
Automotive engineere have been moving the plug around for years and still arn't quite sure where to put it. The advent of the power tip plug is another improvement in the combustion process. by it's very nature it's pretty self cleaning. Unfortunately they can't be used in stock heads. I'm making a fixture to angle then away from the exhaust valve. Thes can improve the economy of your engine by burning a leaner mixture. I'm sure this subject will be tossed around abit, which is good for the advancement of a better runnng flathead.
Old 06-08-2015, 07:07 PM   #27
Scott G
What modifications are needed to run early style heads on later blocks?
Old 06-08-2015, 07:09 PM   #28
JSeery
JSeery's Avatar
Some water passage/hole issues. There have been several threads on the modifications required, fairly minor.
Old 06-08-2015, 07:15 PM   #29
bluardun
bluardun's Avatar
Another two cents: I agree with Ronnieroadster. Your effort for HP will be better spent on multiple fire ignition and quality ignition components. The travel from the spark plug into the cylinder can be improved by grinding a small cannel from the spark plug into the cylinder.
If you do run duel spark plugs, are they going to fire at the same time?
bluardun is offline   Reply With Quote
Old 06-08-2015, 07:26 PM   #30
Bassman/NZ
Bassman/NZ's Avatar
I know where both sets of Flat Attack twin plug heads are. The owner will not part with them, and they are destined for a blown and injected street roadster.
Bassman/NZ is offline   Reply With Quote
Old 06-08-2015, 09:51 PM   #31
Ol' Ron
Ol' Ron's Avatar
Flatattack heads are one of the best designs ever made, work very well with a blower. unfortunately have a large combustion chamber for a normaly aspirated engine. I would mill them to reduce the chamber size for a street engine.
Old 06-09-2015, 03:31 PM   #32
1934calkid
1934calkid's Avatar
Have two sets of these laying around, if you notice they are extremely thick.....LOL...........
1934calkid is offline   Reply With Quote
Old 06-09-2015, 04:17 PM   #33
Scott G
My distributor will clear a pair of heads that are 2 3/4" thick. I have a couple pairs located that should fit the bill. Motor will end up a 3.313 bore 4" stroke. I like the looks of a traditional head compared to the Kongs.
Old 06-09-2015, 05:06 PM   #34
Bassman/NZ
Bassman/NZ's Avatar
Ol Ron, there is a 4-71 blower and Hilborn injection going on this engine.
Old 06-10-2015, 08:32 AM   #35
1934calkid
1934calkid's Avatar
I have a set of these on my garage shelf LOL........
Old 06-10-2015, 10:21 AM   #36
Scott G
Nice collection. 21 stud heads won't work on my 24. Hope the kids don't steal them before you do anything with them! LOL.........
