03-07-2014, 07:56 PM | #21 | |
Re: trying to remove rear drum
03-07-2014, 07:59 PM | #22 |
my suggestion is take two 5# single jack hammers, use one as a back up on one side of the drum snout, smack the opposit side of the snout pretty hard, do that all the way around the snout maybe two times, doing that distorts the snout just a tiny bit, just enough to loosen the bond caused by the taper in the snout, do that with the hub puller attached and with a good pull on the drum, if possible screw the nut on a few threads to stop the drum from flying off and hitting some one,
03-08-2014, 12:12 AM | #23 |
Todd,
Tighten the puller as tight as you can get it, then leave the pressure on it overnight or longer. Cheers,
Walt |
03-08-2014, 10:53 AM | #24 | |
03-08-2014, 11:09 AM | #25 | |
YMMV |
03-08-2014, 11:26 AM | #26 |
03-08-2014, 11:49 AM | #27 |
I had one like this once. After tightening the puller as much as I dared, I then took two 2pound hammers. Placed one on the side of the hub and gave the other side a light smack with the other hammer. The hub popped right off.
Notice: This will likely mar your paint. Good luck.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
03-08-2014, 01:14 PM | #28 |
Hi Todd,
Thinking of hammer methods as opposed to hub pullers, Mr. Paul Moller in his little Red Model A Manual describes a hub removal method of: 1. Allowing the difficult wheel/hub to rest on the garage floor with body weight; &, 2. Next, jacking up the opposite side wheel/hub after turning this opposite axle nut backwards & flush with the end of the threaded axle; &, 3. Then, "Wacking" the raised axle end & flush nut with a hammer. 4. Maybe sounds like a Voodoo Spell Method; but who knows ........ just think ...... the hammer force on the opposite end is "centered" ................... but the resistance force on the difficult hub, instead of being "centered", it is "off-centered", i.e., down low near the garage floor. 5. Could be worth a try! |
03-09-2014, 09:30 PM | #29 |
I got it off, I used my hub puller that bolts to the studs put pressure on it with the center bolt, I tried to hit it with a hammer but nothing. The next thing with the puller on it I used a torch and started to heat it up and after a couple of minutes it popped off the hub so hard it flew two feet on to the floor fortunately I was standing to the side of it. Thanks for all the suggestions.
On a non A related not we received a new toy, passport transport delivered us a fully restored with no miles 37 Buick model 60 convertible with rumble seat today looking forward to showing this car. Todd 3131 |
03-09-2014, 09:53 PM | #30 |
Awesome Todd , great feeling huh. G-man
Never give up, Always fight till hell freeze's over, then we fight on ICE ! |
03-09-2014, 10:02 PM | #31 |
03-09-2014, 11:25 PM | #32 |
Glad you finally got it off!
Blackwall Panthers Nor Cal chapter |
03-10-2014, 10:45 AM | #33 |
Hi Todd,
1. Thanks for being a gentleman by letting us know that you succeeded in getting your difficult hub off. 2. Thanks for taking the time to let us know "how" you got it off. 3. And more importantly, thanks also for reporting on the safety tip of staying clear of the flying hub which could have caused bodily harm to someone holding the torch or just a bystander being very close to the hub removal attempt. 4. Very much appreciated & informative for the next Model A owner's difficult hub removal project. |
03-10-2014, 11:13 AM | #34 | |
todd |
03-10-2014, 01:11 PM | #35 |
Yep, its always good to hear the outcomes. Its a good thing to leave the axle nut on too so the drum doesn't fly off into the next county.
03-10-2014, 01:28 PM | #36 | |
03-10-2014, 02:49 PM | #37 |
Its obvious that some folks don't read the posts, cracks me up.
03-10-2014, 04:25 PM | #38 |
I didn't want it on it had mushroomed before and the outer threads were nonexistent so I didn't want it to mushroom and not be able to get the nut off. I made the correct call for the situation, you would have if you had been there also.
03-10-2014, 04:40 PM | #39 |
Todd,
What I have done to protect the threads as well as keep things from flying off is to take the nut off, turn it around so that the castle part is toward the hub. screw it on till the nut and axle are exactly flush with each other. This provides a larger surface to "hit" on, and at the same time protects the threads from mushrooming. Not saying you did it wrong, just saying this is how I approached it. (Learned this "trick" in the school of hard knocks!)
03-10-2014, 05:35 PM | #40 | |
OK, sorry. I won't do it again. |
