Old 02-26-2014, 06:37 PM   #21
bikejunk
Default Re: engine vibration
just lerned more in the last 10 min. about A engines than I ever knew before thanks!!
bikejunk is offline   Reply With Quote
Old 04-21-2014, 06:17 PM   #22
swede
Originally Posted by tbirdtbird View Post
Tom, you are the wizard of special tools and jigs; what is your solution to my para. # 4 above? dave
....and I too never met an A that didn't vibrate between 45-50....but (and no one believes me haha) that harmonic went away when I installed elctronic ignition (FSI)....go figure....
I just got my 1931 Model A deluxe coupe that needed complete wire job. That is done and after it did not start I read all you guys and thanks a million and now it starts, but at 15 miles an hour I get a vibration from the motor area. The engine idles fine and runs smooth until it revs up and then the vibration. I have timed it 3 times to make sure I did it according to the forum and Henry's manual. The carb has been adjusted according to the manual and know do not what to think.
Monte, from Bow, Washington
swede is offline   Reply With Quote
Old 04-21-2014, 07:13 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
My 29 Tudor was smooth at idle but vibrated bad at 15 MPH and above. Turns out the center babbit was completely gone and laying in the bottom of the oil pan.
Old 04-21-2014, 07:21 PM   #24
bobpo1
bobpo1's Avatar
I'm with you on this one bikejunk.....
bobpo1 is offline   Reply With Quote
Old 04-21-2014, 08:15 PM   #25
James Rogers
James Rogers's Avatar
Ever thought it might be the universal joint?
Old 04-22-2014, 08:41 AM   #26
Dave in MN
Dave in MN's Avatar
[QUOTE=tbirdtbird;831014]Tom, you are the wizard of special tools and jigs; what is your solution to my para. # 4 above? dave
Torque the rear main bearing bolts....Your comment about setting up a bolt...and how it feels to your arms is the only method I know of. I do not have a wrench that works magic in the limited space there is to work in.
And you are right...after many engines, your arm knows you are close on the torque.
Good Day
Dave in MN is offline   Reply With Quote
