Old 02-15-2014, 04:06 PM   #21
Kube
Super Moderator
Kube's Avatar
Default Re: crab- rotor clearance to-cap termanal
Originally Posted by Terry,OH View Post
Ford had a Spec. for the gap between the rotor and the cap. Not only for the 21A but also the other earlier distributors. It is published in the service bulletins about 46-48. Ford did not publish the diameter of the rotor turn circle, so the gap Spec. is more to inform mechanics what the gap between the parts should look like. I do not have the Bulletin with me but from memory the gap is very tight lets say 0.005-8-10. You can view the earlier distributor gaps, to find one with gaps around 0.030, the mechanic knows there is a problem.
Terry, I spent a few moments earlier today looking for, no doubt, the same bulletin you refer to. There is, as you state, a specification and I too recall it being close. I thought it was about .010".
