#21 |
insomniacshotrods,
I find that if I watch the pin while slowly cranking by hand that I can see the pin drop into place. Sometimes the movement is so subtle that it is hard to feel, but I can see the movement. Darryl in Fairbanks |
#22 |
Taking the spark plugs out like Tom suggested makes finding the pin hole a whole lot easer. You can then gently with your hand, sometimes turn the fan pulley to adjust back and forth a bit.
Fred Kroon 1929 Std Coupe 1929 Huckster |
#23 |
Hey you inventors, Dog
![]() ![]() ![]() ![]() (Ol' Bill "THINKS" he read about one, sumwhere thet goes, "CLICK"???? But maybe he's mistaken, he also "THINKS" he hears a "BIRD CHIRPING" sound in his LEFT EAR!!!) Should I WURRY?? Buster T. ![]()
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 12-06-2013 at 02:40 PM. |
#24 |
When I have trouble with the timing pin, I use a short philips screwdriver. The sharper point finds the dimple more easily. Once I find a shallow one, I use a drill and BY HAND remove a little more material to enlarge the dimple. I do this through the timing pin hole.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#25 | |
![]() Quote:
Chief said, "It's close enough for all PRACTICAL purposes, & FARM equiptment" LOL If yo' car does this: 1 Full retard=A smooth & rhythmical-TADA-TADA-TADA-TADA. 2 Half Advance=A faster, smooth idle. 3 Full Advance=An even faster, but a "ROLLING" idle. THEN, IT'S PERFECT, DON'T DOODLE WITH IT! Timing ONLY changes when the point rubbing block wears & decreases the point GAP! Just simply reset your point gap & timing will be PERFECT again. Lube yo' dist. cam with GOOD dist. cam grease, & oil the little pull out oiler in the side of the dist. & while you at it, oil the generator oilers & them 2 little "oil funnels" on yo' throttle crossbar, behind the engine! Do NOT use Vaseline to lube the dist. cam lobe! ![]() ![]() ![]()
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 12-06-2013 at 03:52 PM. |
#26 |
#27 |
Hey cute girls Bill.
Enjoy life , it has an expiration date. |
#28 |
Yo Bill, I jist sent you a PM I ment post 25 instead of 21 in the Pm. Still laughing. Thats jist the way that I pitcher it .
Yer brother Purdy Last edited by Purdy Swoft; 12-06-2013 at 11:22 PM. Reason: correct spelin |
#29 |
Have the two tooth but the bolts at top of column tube are frozen and no way to use penetrating oil. I'm thinking rather than try to drill off the bolt heads, I'll make an extension to the spark rod with a thread-long nut.
Looks like some kind of gasket was 1/2 removed up at the column tube bracket for securing to the dash. appears digging it out would loosen tube enough to rotate & resolve retard travel. thinking I could glue some kind of split seal into the bracket. I remeber something on an engine rear seal long ago. what do you think? THanks, Dick |
#30 |
You don't move anything at the top of the column, you loosen the one bolt that
hold the clamp at the bottom of the column and twist the whole mast . Bob |
#31 |
#32 | |
![]() Quote:
#33 |
Man I hear you about finding the recessed dimple with the pin. I tried all kinds of stuff, knitting needles, wooden dowel, screwdriver, mirror and flashlight like the Romans used to do with mirrors and the sun to illuminate the Pyraminds ,etc. Got so mad I took off the front cover, installed a new cam gear and enlarged the TDC mark on the gear with a drill. End of problem.
Now if I only had an operable distributor to time !! |
#34 |
Duhh, I forgot about the clamp at the gas tank. I thought he was talking about
something at the top by the steering wheel. ![]() Bob |
