Old 10-23-2013, 05:39 PM   #21
FlatheadTed
FlatheadTed's Avatar
Default Re: Harmon Collins Rotors ?????
looks the part .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-23-2013, 06:00 PM   #22
DzusFast
Well, thought I'd at least post what I have to see if anybody actually needed any. Nothing worse than having a dead horse in the stable.....
DzusFast is offline   Reply With Quote
Old 10-23-2013, 06:09 PM   #23
KiWinUS
KiWinUS's Avatar
Put me on the list for 1 or 2 please !!!
they look magnificent !!!
Thank you so much !!!
Cheers
Tony Price
Old 10-23-2013, 06:22 PM   #24
NealinCA
NealinCA's Avatar
Please let us know the details, I would be interested in a couple.
Thanks,
Neal
NealinCA is offline   Reply With Quote
Old 10-23-2013, 06:55 PM   #25
DzusFast
Thanks,
Neal
The details.... the project started over a year ago in solidworks. (a cad/cam program) made the mold and materials then interest was lost. Charlie ny isn't far off on the cost. I'd like to see enough orders to help fill that gap and I'd be happy to finish the tooling and make a small run. I'd really like to do them in tan color, the material wasn't available when the sample run was made.
The screw will be replaced with a brass rivet. Also, the brass terminals will be stamped... this one was fashioned by hand.
I added this picture to show more detail:
Old 10-23-2013, 07:37 PM   #26
barnfind08
Put me down for a couple.
barnfind08 is offline   Reply With Quote
Old 10-23-2013, 08:56 PM   #27
Strick
Strick's Avatar
Strick is offline   Reply With Quote
Old 10-23-2013, 09:32 PM   #28
super flat
super flat's Avatar
I am in for 2 please. Gary
super flat is offline   Reply With Quote
Old 10-23-2013, 09:48 PM   #29
Ol' Ron
Ol' Ron's Avatar
You the man, that's beautiful>>
Old 10-23-2013, 10:16 PM   #30
Gary Duff
I do the Harman Collins dual coil here in Seattle. If whomever is going to do this, I
would be interested if they make both the rotor and the inner cap. I would like to see the inner cap made without the primary connections as part of the inner cap. They are a major source of high tension shorts, so I bring out the primary differently.
Put me in for a dozen if this gets out of the planning stage. Gary
Gary Duff is offline   Reply With Quote
Old 10-24-2013, 08:10 AM   #31
alchemy
alchemy's Avatar
DzusFast,
Send the sample to Bubba for testing. If it works as designed, we'll be lined up at your door.
alchemy is offline   Reply With Quote
Old 10-24-2013, 09:04 AM   #32
Bruce Lancaster
I want a couple even before testing! Gotta be better than my broken one...and I'm betting on it being a lot better, given the source and care shown so far.
(I assume you'll be mentioning this on the HAMB...that'll likely bump you from potential dozennaire to potential zillionnaire!)
Bruce Lancaster is offline   Reply With Quote
Old 10-24-2013, 09:18 AM   #33
moonlight graham
I'm interested in a couple as well.
Geoffrey
moonlight graham is offline   Reply With Quote
Old 10-24-2013, 11:57 AM   #34
DzusFast
Wow, looks like I better get to work guys....I will definitely keep everyone updated on progress; thanks for the support!
Old 10-24-2013, 12:15 PM   #35
Chris Marshall
Chris Marshall's Avatar
A lifesaver!! I had considered selling my HC due to a bad rotor, now I can hopefully run it.
Chris Marshall is offline   Reply With Quote
Old 10-24-2013, 01:07 PM   #36
Bruce Lancaster
And start tooling for that blasted lower cap!
I have bits and pieces from some of those stock Ford (59) cap dual coil conversions...these are interesting because they made the conversion with no need for any extra plastic or much more technology than a drill press...they simply added a contact to the back end of the stock rotor and screwed in a brass ring around the center of the cap! I think they used same type plate conversion as HC, though there are no labels on the partial distributors I have to prove anything.
If someone simply made brass rings and tabs, and accurately drilled some points plates, that would be a cheap and easy conversion replicating an actual traditional part. It would make sense to do it with some compact common points, too, like '60's Mopar or '50's Ford. It seems silly to chase down weird old magneto points from antique cement mixers and aircraft for a simple conversion on a fairly low RPM battery ignition.
Old 10-24-2013, 02:21 PM   #37
DzusFast
Originally Posted by alchemy View Post
DzusFast,
I spoke with him, and sending one out today.
Old 10-24-2013, 02:46 PM   #38
NealinCA
NealinCA's Avatar
Looking forward to hearing how it works. Bubba is working on some of my H/C distributors right now.
I'll spread the word about this project and try to drum up some more interest for you.
Now, I wonder how long before Drake starts shipping back-orders on the caps?
Neal
Old 10-24-2013, 07:24 PM   #39
russcc
Nice work. You have ready market for them from we see on this post.
russcc is offline   Reply With Quote
Old 10-24-2013, 08:45 PM   #40
flatheadz-forever
I May need a few
flatheadz-forever is offline   Reply With Quote
