Old 04-16-2018, 09:16 PM   #21
Ford Freak
Default Re: How do I buy Bob Sherman thermostats?
Originally Posted by Bored&Stroked View Post
Me, I just use a 1" piece of stainless tubing that sits on-top of each thermostat (The OD of the tubing is the same as the hose ID). Then I put a second hose clamp to hold it in place. Super simple to setup and works flawlessly.
B&S
I do the same except I just squeeze a smaller piece of old radiator hose about 2 in . long in the hose . No clamp needed .
Ford Freak is offline   Reply With Quote
Old 04-16-2018, 11:16 PM   #22
Drbrown
Drbrown's Avatar
Bored&Stroked and Ford Freak: I do same but use a 1 inch high piece of straight radiator hose, glued inside the stock hose with rubber cement, then one clamp inn normal location to hole the whole thing. The thickness of the inner hose piece does not hinder the flow of coolant through the stats, which are Stant units. Found that method in an older thread here on the Barn.
Drbrown is offline   Reply With Quote
Old 06-02-2018, 05:21 PM   #23
mijusow0
Originally Posted by Old Henry View Post
gkgeiger, if your engine is the 59A or earlier stick with the Stant stats but test them to make sure they work before installing them. Also, make sure you get them in right side up and secure them with either an extra hose clamp above them or wires down the side of the neck. Otherwise, they will likely get pushed up out of place, turn sideways, and do nothing. As I think more about the problem you've had, that may very well be it. Here's how I secure my thermostats in the neck of my 59A engine.
I pull a single strand of wire out of a piece of stranded wire,
Cut it to 3½" length.
and thread it through both sides of the thermostat like this.
Then drape the wires down the side of the neck like this.
Then push the hose down over it and tighten the hose clamp being sure that the clamp is at the top of the neck to grab the wires rather than at the bottom and possibly miss them.
Very useful guide. Thank you!
Crazy Bulk Supplements line https://diets-usa.com/crazy-bulk-reviews/ is useful for you
mijusow0 is offline   Reply With Quote
Old 06-03-2018, 09:42 PM   #24
Old Henry
Old Henry's Avatar
Default Re: How do I buy Bob Shewman thermostats?
I've since suggested one improvement on this idea. Twist the single strand of wire on itself on each side so that only one strand has to be compressed by the hose instead of two. It also holds the wire in place better during installation.
Old 10-11-2018, 11:42 AM   #25
davidkidd
I've since suggested one improvement on this idea. Twist the single strand of wire on itself on each side of the crazy bulk review on fitness donkey site so that only one strand has to be compressed by the hose instead of two. It also holds the wire in place better during installation.
That seems like even a better idea. Thanks for sharing and keeping us updated.
davidkidd is offline   Reply With Quote
