Old 06-22-2013, 10:25 PM   #21
ctvpa
ctvpa's Avatar
Default Re: Need help!!! Please!!
Mitch,
You are the type of person that makes our hobby, this site, and all the people safer, grateful and allow us to enjoy the cars we love. This is a very nice thing you did.
Craig
ctvpa is offline   Reply With Quote
Old 06-22-2013, 10:38 PM   #22
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Way to go Mitch!!!
Old 06-23-2013, 07:59 AM   #23
Cape Codder
Cape Codder's Avatar
Mitch,
Sure appreciate you taking care of my friends from the Cape like that. And I'm sure Paul appreciates it also. Yes, that is their FIRST national and the crazy thing is that it was my idea to go to Lexington but I have had engine problems also so I backed out.
Thanks again for being so nice.
Joe Grobleski
Cape Codder
Cape Codder is offline   Reply With Quote
Old 06-23-2013, 08:37 AM   #24
1931 flamingo
1931 flamingo's Avatar
Having met Mitch at the "Cider Mill" get together, he's a great person and a credit to this hobby. NOT JMO evidently
Paul in CT
Old 06-23-2013, 11:53 AM   #25
mpalilonis
mpalilonis's Avatar
Mitch will get it going... He fixed my A when it had an electrical problem. Great A Mechanic!
mpalilonis is offline   Reply With Quote
Old 06-24-2013, 01:37 PM   #26
Mitch//pa
re::::update
the truck has a v-8 pressure plate and lightened flywheel
you guys would never guess what happened
Old 06-24-2013, 02:15 PM   #27
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by Mitch//pa View Post
re::::update
Two thoughts, the clutch disc spline came loose (springs) where it just spins?
2nd thought, the bolts sheared on the pressure plate?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-24-2013, 02:15 PM   #28
QGolden
QGolden's Avatar
Hmm, I'll take the first guess... clutch disc binding on the spline shaft, due to misalignment of the clutch to the machined Flywheel?
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 06-24-2013, 03:03 PM   #29
Mikeinnj
Mikeinnj's Avatar
Good job there Mitch ! Let us all know what the problem was when you make the repair.
Mikeinnj is offline   Reply With Quote
Old 06-24-2013, 03:21 PM   #30
Tom Wesenberg
Tom Wesenberg's Avatar
A picture would help me guess.
I'm sure the disc wasn't installed backwards.
Maybe a spring popped out of the disc?
An arm broke on the pressure plate?
The lining tore loose and doubled up?
How about a clue...........can it be fixed with duct tape?
Old 06-24-2013, 03:37 PM   #31
Purdy Swoft
Purdy Swoft's Avatar
The input shaft could have broken, just in front of the large front transmission bearing. I had that happen once.
Old 06-24-2013, 03:37 PM   #32
Mitch//pa
toms the closest he wins a free vacation to my shop and gets to work for free and food.
Old 06-24-2013, 03:48 PM   #33
Mitch//pa
before removal i checked linkage pins etc and noticed that one of the three pressure plate arms was just flopping around not doing its job to disengage the clutch. but upon further inspection of that particular arm i could not see why. we pulled the trans from the back end leaving everything attached. (the flat rate way)..put the fork lift under the differential unbolted everything and slid it back as an attached unit with trans connected to the torque tube. dropped out the clutch which looks brand new like right out of the box no heat scorches or wear. the flywheel looked just as good with a nice crosshatch pattern as does the clutch plate. each of the 3 fingers pivot on a metal pin held in by a tiny snap ring. one of the snap rings came off and the pin walked its way out. the pins are knurled under the heads to make it a slight pressed fit but it really seems like a chinsy design. we reinstalled the pin and got a new snap ring and put a tiny tack weld on each of the 3 pins so even if the snap rings broke again the pin cant fall out.
here are the pics showing the flat rate R&I,,,the clutch plate disassembled with the pin hanging out..
Old 06-24-2013, 04:45 PM   #34
Lawrie
Lawrie's Avatar
That is good info, thanks for posting the problem,so those of us using the v8 PP .can check them.
Lawrie
Lawrie is offline   Reply With Quote
Old 06-24-2013, 04:48 PM   #35
Mitch//pa
Lawrie
i would put a tiny tack on the other end on every one. i would never trust that tiny snapring and the groove for it is very shallow
Old 06-24-2013, 04:57 PM   #36
RonC
RonC's Avatar
Is that the clutch disk that fails due to missing upset of metal around the springs?
http://www.fordbarn.com/forum/showth...4991&highlight
RonC is offline   Reply With Quote
Old 06-24-2013, 05:08 PM   #37
V4F
V4F's Avatar
don't scratch it !
V4f
V4F is offline   Reply With Quote
Old 06-24-2013, 06:01 PM   #38
1931 flamingo
Mitch: Is that a V8 PP?? If so I wonder who the vendor/supplier was??
Most guys on the EV8 board swear by Fort Wayne Clutch.
Nice looking truck IMO>
Paul in CT
Old 06-24-2013, 06:23 PM   #39
Mitch//pa
Paul in CT
paul,
yes it is but i am not sure where it came from.
i finished the truck before i left, took it for a quick spin and all is good. its up on the drive on lift now covered and out of the way till they pick it up.....
Old 06-24-2013, 10:58 PM   #40
KR500
KR500's Avatar
Mitch, Doesn't the V8 pressure plate use any heat insulators on the springs to keep the heat from the pressure plate from transferring to the springs?
KR500 is offline   Reply With Quote
