Old 04-19-2013, 01:49 AM   #21
hardtimes
hardtimes's Avatar
Default Re: aluminum head erosion
Hey 49r,
'anti seize' installed on the head bolts also help prevent seizing that you described.
hardtimes is offline   Reply With Quote
Old 04-19-2013, 04:00 AM   #22
49r
Originally Posted by hardtimes View Post
Hey 49r,
Thanks Hardtimes. I've since only used thread sealant on the threads and haven't thought to put anything on the bolt shanks. Haven't had issues with cast iron heads, but do have a new set of Edelbrocks which I'm thinking carefully about before installing.
49r is offline   Reply With Quote
Old 04-19-2013, 07:49 PM   #23
feelsharp
Snyder's and most other "T" parts houses sell them under the name of head savers.
feelsharp is offline   Reply With Quote
Old 04-19-2013, 08:53 PM   #24
Ol' Ron
Ol' Ron's Avatar
When I was rebuilding heads I would bead blast the eroded area an fill it with JB weld then mill then flat. worked great.
