Old 05-14-2013, 04:48 PM   #21
Matt in Alameda
Default Re: good idle...no rpm
Sorry, I should add that compression is 125# in each cylinder......vacuum is 10" steady on a no start crank..and 19" very steady at idle of 600...at least it was when it started, which it refuses to do right now... also, I have a pressure valve and fuel pressure gauge...it is pumping at 2#...the carb is a Holley 94....Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 05-14-2013, 04:58 PM   #22
ken ct
Matt you have so many non-stock changed items on there its hard to figure out whats the matter with it. ????? ken ct.
ken ct is offline   Reply With Quote
Old 05-14-2013, 05:02 PM   #23
ken ct
You also cannot buy a exact replacement NEW made carb for that model.They are the 8BA type that are being sold. You will not have all the hookups that the #59 has. ken ct. Nothing wrong with a 75 yr old rebuilt carb if done right. OMO.
Old 05-14-2013, 06:54 PM   #24
Marv
Marv's Avatar
Matt before i would buy a new or rebuilt carb i think i would take the carb that you know was good before you put it on your car and put it back on a car that is running good and see if it still works. If it does , then the carb is not the problem If it doesnt work it proaably is dirt in the tank and lines and that carb will need cleaned. marv
Marv is offline   Reply With Quote
Old 05-14-2013, 08:59 PM   #25
FlatheadTed
FlatheadTed's Avatar
Maybe you should work with one of us instead of spending more money ,If you can answer yes or no then we can take you onto the next thing to look at ,For instance what color is the spark of the plug lead when cranking ??? yellow or blue .or does it have any ,??
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-15-2013, 08:00 PM   #26
rossodino34
rossodino34's Avatar
With out getting long winded, I smell a coil problem. When the coil is bad everything is bad !
rossodino34 is offline   Reply With Quote
