12-12-2020, 01:14 PM | #21 | |
Re: Does Your A Start Right UP?
I don't get the rush on the spark advance at all. Won't everyone's car run just fine fully retarded? |
12-12-2020, 02:06 PM | #22 | |
I have 12v and it spins pretty fast, even tho the starter is converted to 12v. Also I have a Phillips Advancer (Nu-Rex) so I don't have to fiddle with the timing. |
12-12-2020, 02:08 PM | #23 |
I liked this post because it describes my Victoria. It starts quickly, runs then stalls. But it starts again promptly. Its like the car was taking a nap and suddenly it was awakened and now it is stumbling around trying to figure out what is happening! This is what I think is happening. On those first few engine turns, the car is running lean and steps have to be taken to get to a normal fuel/air ratio.
1. Open the gas shutoff valve. Take your time, pause a bit while the carb bowl is filling and gas is flowing into the Secondary Well to feed the Idle Jet and the Cap Jet. 2. Open the GAV an additional 1/2 turn so that some additional gas can get to the Cap Jet. 3. Pull down the Throttle Lever very slightly for a "not to fast" idle. This is an important step because the Throttle Plate is very close to full closed and very little gas and air is going past it into the engine. Even with a full choke, gas from the Main Jet and Cap Jet will be minimal. Remember you have your foot on the Starter and cannot step on the Gas Pedal. 4. Pull the choke for 1-2 engine turns and release it. The engine will start and with any luck it will stay running. After the car is warmed up, turn the GAV back a half turn. That's my take on it! Ed |
12-12-2020, 02:16 PM | #24 |
12-12-2020, 06:45 PM | #25 |
12-12-2020, 07:15 PM | #26 |
Fuel drain out of the carb? Fuel shutoff OK? Carb clean? rings free? Put a little Seafoam in the engine to soak the rings lose. Carb bolts tight to the intake manifold? These engines like to start. Happy holidays. Rings free? Put a little seafoam ?in the gas tank or crank case ? I am interested soak rings lose ,I would like to know how thank you for your help Joe! |
12-12-2020, 07:25 PM | #27 |
Just don't be like me and forget to turn the gas on when starting. It took me two days to figure out why it wouldn't start. Ran my battery down too......ugh. But it's fine now, except for a radiator leak...UGH!!
John |
12-12-2020, 08:23 PM | #28 |
Today is in the 40's here. I did a hand-crank from a cold start and the car has not been run for a week. I did two pulls of the crank with the ignition switch off and fully choked. Released choke and turned on ignition. It started on the first pull. And kept running.
12-12-2020, 08:26 PM | #29 |
Most of us have forgotten to turn the gas valve on, So, Been there, done that. Pretty annoying to start it up for a parade and have lots of folks behind and then it dies....
12-12-2020, 08:31 PM | #30 |
My carb had been getting flaky lately so I tossed it in a gallon of carb cleaner overnight after taking it apart. Lots of white crystals (I assume from ethanol during its previous life)... Plopped it back together after a hot wash in Dawn infused water and it fired right off and tuned up well. Lot smoother idle and little gurgling at idle.
I have a big B cab in the bucket now. Hoping for similar results with it. Not bad for $30 in juice and eventually some gaskets.
Building a '29 Speedster, the hard way... |
12-12-2020, 09:56 PM | #31 |
Ethanol sucks!
12-14-2020, 12:35 PM | #32 |
12-14-2020, 05:19 PM | #33 | |
Thanks Steve |
12-14-2020, 07:13 PM | #34 |
You have to run a wire or string from the choke lever on the carb to the front. That’s what the little hole is for on the bottom of the lever.
12-14-2020, 07:18 PM | #35 |
Oh, ok.. Thank you.. I will have a go at it later on. I have been able to crank it when it is warm, very easily. But hadn't quite got the knack of the cold start..
12-14-2020, 07:28 PM | #36 |
One day when the battery was down and I needed to crank start I needed a wire to pull the choke, what I usually do when I am broke down is walk 100 feet and cross over the road and walk back ---found this wire, I open the carb side hood and hook the wire in the hole in the choke lever --it comes out to just in front of the rad shell
So my hand crank procedure is--gas on, spark retarded,proper fast idle throttle setting (i pull lever till see slight movement of gas pedal),GAV about 1.5 open, ignition off I pull through 4 compressions with choke pulled,--ignition on, usually one pull of the crank, I have even done it with temperatures in the 30s |
12-14-2020, 10:57 PM | #37 |
12-14-2020, 11:19 PM | #38 |
I would also caution you not to wrap your thumb around the crank when you pull it up. Pull with an open palm. You can break your thumb otherwise if there is a backfire.
12-16-2020, 08:46 AM | #39 |
12-16-2020, 04:11 PM | #40 |
I really don't think you have anything to worry about. Mine has done this as you describe depending on climate and how long it's been since it was last started. If it sits a week, yeah it'll require 2 starts. If it's been 7 hours, it'll start the first time.
If it's not holding you back, I really wouldn't worry about it. Some engines are just more cold natured than others. I go start a widow's Model A's about twice a year. Her coupe will start every time and stay running on the first start- without a choke. I'm not kidding, you don't have to choke it. Her sedan however will fumble and have to be cranked 2 or 3 times before it stays running. I do have to choke this one.
Cowtown A's |
