Old 05-12-2025, 01:42 PM   #361
sidevalve8ba
sidevalve8ba's Avatar
Default Re: What did you do today that was flathead V8 related?
That looks like a beauty, Steve but I've got a 12 volt generator on the '32. Sorry I missed you at Luray, it was certainly a good meet.
sidevalve8ba is offline   Reply With Quote
Old 05-12-2025, 03:27 PM   #362
ndnchf
ndnchf's Avatar
Maybe next time !
Restored Ford 6 & 12 volt generators
ndnchf is offline   Reply With Quote
Old 05-13-2025, 09:17 AM   #363
37 truck
I drove my 37 pickup out of the shop with all the fenders, running boards and lights working and attached for the first time in 20 years.
37 truck is offline   Reply With Quote
Old 05-13-2025, 09:27 PM   #364
slowforty
Went for a ride to test out the new transmission. (worked well) Just got far enough away,where it was too far to walk back, and the 40 died, Good fuel and battery no spark at the plugs.
Adventures in car hobby. Came home on the Rollback. AAA to the rescue.
slowforty is offline   Reply With Quote
Old 05-15-2025, 07:16 PM   #365
Lisas38
Lisas38's Avatar
Today started yesterday when I started pulling valve assemblies out of the '38 V8-60. I borrowed the long 'pickle fork' tool from my machine shop. It kept slipping and missing the grooves. I finally managed to get one of the exhaust valves out. That's when I discovered the fork opening is too big for the little 60. So I modified a flat prybar I had to have an opening that fit the removed guide. Pics below. I got the rest of the exhaust valves out pretty easily since they all moved when the spring was pulled down.
None of the intakes would move (I'm curious if there is a well known explanation.) I left them over night to soak in as much PBB as I could get to them. Today they were still stuck hard. I broke part of one of the guide grooves and realized I need a new approach. I used the clamping valve remover to lift the spring and remove the bottom stem key. Then I used a 1-1/2 inch section of 1/2 inch PVC with a lengthwise slot that fit under the valve head and rested on the guide. A couple of whacks with a dead-blow hammer and the horseshoe key was free to remove by hand. The clamp went back into service and finished pushing the guide out. This worked amazingly well.
Dan
'38 V8-60 Tudor Humpback
Lisas38 is offline   Reply With Quote
Old 05-15-2025, 07:22 PM   #366
fordv8j
fordv8j's Avatar
Took distributor off our 38 convertible coupe, filed and re-set points; put new bolt and washers on end of new master cylinder to stop leaks
fordv8j is offline   Reply With Quote
Old 05-16-2025, 02:06 AM   #367
vincent
First start of the modified beltdrive of my blown french flathead. Started instantly and sounds very angry.
vincent is offline   Reply With Quote
Old 05-16-2025, 03:05 AM   #368
Mart
Mart's Avatar
Wow. Nice setup, Vincent.
Old 05-16-2025, 06:40 AM   #369
Oliver1932
Beautiful job !!
Oliver1932 is offline   Reply With Quote
Old 05-16-2025, 06:44 AM   #370
Oliver1932
Nice restoration !! like it should ...
Old 05-16-2025, 07:45 AM   #371
vincent
Thanks Mart!
Old 05-16-2025, 11:08 AM   #372
petehoovie
petehoovie's Avatar
Old 05-16-2025, 07:43 PM   #373
TomC750
TomC750's Avatar
Installed front seat belts in the '41 Merc. Nice product from Seat Belts plus. My only gripe is them using FedEx. Delivered to wrong address again! Put me a day behind.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 05-16-2025, 08:20 PM   #374
Joe Rust
Not as exciting as most but did my first post here and spent a few hours searching parts (aka dreaming) for the 8BA in my '46 Super Deluxe.
Joe Rust is offline   Reply With Quote
Old 05-17-2025, 04:23 AM   #375
ndnchf
ndnchf's Avatar
That's why we started this discussion - to have a place where people could post little things thay may not seem worthy of a standalone discussion. Welcome aboard!
Old 05-17-2025, 08:16 AM   #376
farmertom
farmertom's Avatar
i used seat belts plus in my '37 nice product,and very good price. Tom.
farmertom is offline   Reply With Quote
Old 05-22-2025, 08:24 PM   #377
TomC750
TomC750's Avatar
Well, I saved my '41 Merc from a 4' Black snake intrusion. Was headed for the car. This spring I had one thread its way into the undercarriage of my side by side. I did not want for the same to happen to the Merc. Went to lunch, came back and found another, a bit smaller. My bride of nearly 62 years helped me remove both to the woods. What a partner! By the way, she loves the Merc.
TomC750
1930 1 Ton White
Old 05-22-2025, 10:10 PM   #378
hueyhoolihan
my new-to-me '41 Ford Super Deluxe convertible (lachaven green) was hauled from the consigner to my storage unit today. very pleased with everything, now that i've had a good chance to take a close look at it.
such simplicity and what quality! they were built like a WWII Soviet T-34 tank!
i have recently sold after owning them for four or five years, a 2007 Porsche and Aston Vantage and still own two vintage British cars: a '53 MG and '67 Jaguar Mk2, but this older ford puts them to shame as far as construction and materials quality. i'm amazed. from now on i might be an American made kind of guy, at least as far a vintage automobiles are concerned.
hueyhoolihan is offline   Reply With Quote
Old 05-23-2025, 07:39 PM   #379
slowforty
Replaced coil adaptor with spare one. starts and runs but not good.
Got a new coil adaptor, problem solved .
Old 05-23-2025, 08:54 PM   #380
Kens 36
Kens 36's Avatar
Replaced the leaking heater core in my 1950 Ford convertible with a new one from Brassworks. Went a lot quicker than I expected.
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
