Old 01-01-2016, 02:25 PM   #1
petehoovie
petehoovie's Avatar
Default Re: Please post pictures of 1933-1934's here
@David J - That sure is a nice 'straight' 5 window you have there....
Old 01-01-2016, 04:37 PM   #2
David J
David J's Avatar
Thanks and it sure gets a lot of phones pointed at it driving it around . The leave it alone comments beat the paint it comments about 3-1 . Definitely going with the majority on that one . Probably dreaming but a NOS LH runningboard with shelf wear would finish it off . David J
David J is offline   Reply With Quote
Old 01-01-2016, 05:04 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Darn.......I still have a couple of these from my Bloomington Gold days in the early '90s. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-02-2016, 08:13 AM   #4
stangblue
stangblue's Avatar
V8COOPMAN, Those where the days and still to a lesser degree than before! Now I repeat that mantra to myself every morning. ha!
Assumption is the mother of all foul-ups.
stangblue is offline   Reply With Quote
Old 01-01-2016, 03:25 PM   #5
1934
1934's Avatar
Here's my 4-door.
1934 is offline   Reply With Quote
Old 01-01-2016, 03:43 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 1934 View Post
Here's my 4-door.
Have you replaced the rear end with one from 1935 or later? Wondering why the rear sits so far forward! DD
T5 W/TORQUE TUBE
Old 01-02-2016, 07:59 AM   #7
1934
1934's Avatar
DD, you're right, I think the rear spring was put on backwards at one point which puts the rear end too far forward. Doug.
Old 01-02-2016, 11:03 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
Doug....Interestingly, putting the spring on backwards (IF that is actually possible) would move the rear end REARWARD. The spring ENDS and crossmember arc toward the front.
One other possibility......IF the car was changed-over from a 4-cylinder to a V8, or some such scenario, a 4-cylinder torque tube and driveshaft are shorter than the V8 parts. If they were not swapped for the longer V8 parts, bolting the torque tube to the transmission mount would pull the rear assembly forward. If that is a possibility in this case, we have dimensions for the 4-cylinder and V8 torque tubes so that you could measure yours. DD
T5 W/TORQUE TUBE
Old 08-09-2017, 12:09 AM   #9
bluesman
Here is mine 1933 standard model V8 21k original miles Duncan blue with black fenders one repaint back in the 60s windshield frame was changed to chrome other than that all original...love model 40s...
bluesman is offline   Reply With Quote
Old 01-01-2016, 04:03 PM   #10
stangblue
stangblue's Avatar
Thanks VeryTangled The middle one is mine.
Old 01-01-2016, 05:19 PM   #11
VeryTangled
VeryTangled's Avatar
Hi Everyone, Hershey show cars 2013
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 01-01-2016, 05:54 PM   #12
Warren Kelley
My son's 34 Roadster, all steel, mechanical brakes, 6 volt but with a C59a in
place of the 221cu.in.
Warren Kelley is offline   Reply With Quote
Old 01-01-2016, 08:21 PM   #13
guy1unico
Here is mine.
Pretty original.
guy1unico is offline   Reply With Quote
Old 01-01-2016, 08:22 PM   #14
Flathead37
Flathead37's Avatar
This is my fathers Phaeton
Flathead37 is offline   Reply With Quote
Old 01-01-2016, 08:27 PM   #15
Flathead37
Flathead37's Avatar
Another picture of my fathers.
Old 01-01-2016, 08:32 PM   #16
Flathead37
Flathead37's Avatar
And one of my roadster
Old 01-01-2016, 08:38 PM   #17
Flathead37
Flathead37's Avatar
My collection of projects
Old 01-01-2016, 09:06 PM   #18
331Cadillac
331Cadillac's Avatar
David J. , is your 33 Old Chester Grey?? My car was that color and I would like to see a picture of a car in that color.
331Cadillac is offline   Reply With Quote
Old 01-01-2016, 10:47 PM   #19
David J
David J's Avatar
Yessir
Old 04-22-2016, 10:49 PM   #20
34billct
34billct's Avatar
34billct is offline   Reply With Quote
