#241 |
I built a oddball, one-off 12v generator for an 8BA engine going in an early 30s car with fan mount pulley. A lot of different year parts were used, and a lot of work. Not somthing I intend to do again. But it works well.
#242 |
Love post 241 as I’m about to have the generator on the 37 Ford rebuilt & possibly a new voltage regulator. Found out the hard way the battery didn’t seem to be charging.
For the 1953 Merc, I managed to get new tires installed today. Car rides beautifully and “feels” like it has power steering (it doesn’t). One of the many steps of getting her ready for the CNM in June ! |
#243 |
May I ask : Were the new tires bias-ply or radials? What about the ones you replaced?
#244 | |
BFGoodrich Silvertown Radial | 2.50 Inch Whitewall | 215/75R15 Old tires were from 2003 per the date code. I’d say they were overdue. Last edited by kingeak; 01-30-2025 at 06:14 AM. Reason: Pics added |
#245 |
Drove it to dinner.
Kelly Burns |
#246 |
#247 |
The sun came out early this morning, so I took Miss Daisy for a little ride. This car is always a pleasure to drive.
#248 | |
#249 |
Working on the 6
#250 |
I ran down the road a few blocks in 80 degree weather and got hot. LOL
#251 |
Woke up my 40 to put in a local Netflix Movie. Free storage for 7 weeks. Too bad I neglected the car over the winter and spent two hours getting it running. When will i ever learn.
#252 |
I just got home from Oregon where I was working on my 41 pu. I learned the hard way (AKA things you'll never forget) to always check you valve to head clearance. The heads worked fine on a original 8BA but the new stainless valves have thicker/taller head then the originals from ford. Yes the heads were milled sometime in the past and I did the tinfoil balls on the pistons but not the valves. Needles to say , I didn't get it runnig this trip, maybe next . Tim
#253 |
Successfully serviced my 1934 dual temp gauge to accurately register the amount of gas in my tank.
#254 |
Very good, they can be persnickety
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#255 |
Not a V8 ,but model A.
Straightened and repaired the bent front radius rod from my model A, man that is made from tough stuff, also the top left hand perch mount was worn miles out of round, so made a new one and cut the old one off and welded the new one in place. Also trued up the old perch bolts and cleaned up the threads . Lawrie |
#256 |
Finally got the radiator grille shell on my truck. Had to fight with the stainless steel trim as it had it's own mind made up of a shape different than what I needed, but lots of hand tweaking finally got it nailed down. Then was able to get the NOS radiator grill emblem mounted with the correct cad-plated backing plate and chromium-plated screws. The radiator ornament is re-chromium plated NOS. Nothing fits so nice as original parts!
Now onto the fender skirts and hood.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
#257 |
Spent over $200 to replace all the valves I bent on my new motor. Gerrrrrrrrr. Tim
#258 |
Replaced the Voltage Regulator on my 41 pickup. Charges good now. Have been preparing my 32 sedan for paint. Long ongoing job.
#259 |
I just finished restoring this 1938-1939 style 3-brush generator with refurbished original Ford cutout.
#260 |
Drove the mercury to a model T club meet then to tractor supply for some parts. Needed to get her out for a drive.
