Old 05-24-2012, 12:05 PM   #181
frenchy dehoux
frenchy dehoux's Avatar
Default Re: What I Did on My Lunch Hour
Originally Posted by Ken/Alabama View Post
Hey Vic, Is your nos u-joint one of the Lincoln joints with needle bearings or a Ford joint ? Im considering putting a Ford joint in my Zephyr,every Lincoln joint I have seen is worn out . Seems to me there would have to be some thin grease in there to work its way into one of those Lincoln joints. Anyone else have any thoughts on this ?
Ken
Just to let you know I have a new Zephyr U joint in my 39 Zephyr trans and originally I was going to install a Ford U joint to find out it will not work on the Zephyr splines as it is smaller and doesn't go on. The Zephyr spline comming out of the transmission is different than the Ford I was hoping to change it for the Ford style because there are more of them than the Zephyr and cheaper.
Frenchy
frenchy dehoux is offline   Reply With Quote
Old 05-24-2012, 01:50 PM   #182
Vic Piano
Vic Piano's Avatar
Originally Posted by frenchy dehoux View Post
Ken
Frenchy
Frenchy & Ken,
The U joint I used was on the back of a '46 Ford transmission that I got several years ago, it fit with no problems. The Ford & Lincoln part #'s are the same, B-7090 for the U Joint Assembly.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 05-24-2012, 01:53 PM   #183
frenchy dehoux
Originally Posted by Vic Piano View Post
Frenchy & Ken,
Vic
Thanks I was told they were different spline from the Zephyr and Ford.
Frenchy
Old 05-24-2012, 03:47 PM   #184
Ken/Alabama
Ken/Alabama's Avatar
I was thinking the two transmissions shared the same mainshaft
Ken/Alabama is offline   Reply With Quote
Old 05-24-2012, 05:03 PM   #185
Vic Piano
Vic Piano's Avatar
Everything but the case is the same in the '39 Ford & '39 LZ transmission as far as part #'s go. I used all Ford parts; it pays to cross reference part #'s as a lot of Ford & Merc parts are used on the LZ.
Old 05-24-2012, 05:45 PM   #186
frenchy dehoux
Vic
Thanks for the info.
Frenchy
Old 05-29-2012, 06:41 AM   #187
Vic Piano
Vic Piano's Avatar
I hope everyone enjoyed the long weekend and remembered those that gave their lives to protect our freedom... I got nothing done as far as working on Flatheads goes (still haven't put the plug wire looms in) but I've been enjoying driving the LZ with all the other new parts installed. I’m going to pull the distributor to clean/service it and install the new gasket set. Here’s a question, do any of you know if the terminal plates have corresponding numbers (relating to which plug wire goes where) on them?
Old 05-29-2012, 07:03 AM   #188
41ford1
41ford1's Avatar
According to the verbiage in the manual they are marked like the V8 caps. The following was pulled from the section on the V12.
ASSEMBLY.
Note the numbers on the wire ends. Insert the wires
in
their proper positions in the distributor caps and conduit, and connect
the other end of the wires to the corresponding numbers in the
terminal plate.
41ford1 is offline   Reply With Quote
Old 05-29-2012, 07:53 AM   #189
Vic Piano
Vic Piano's Avatar
Thanks, I thought it would be like the V8's but I wasn't sure, I appreciate the information.
Old 05-29-2012, 04:58 PM   #190
Vic Piano
Vic Piano's Avatar
Today I finally got a chance to mess with the LZ so I installed the plug wire looms, pulled the distributor, cleaned it up, put new gaskets, etc. Later this week I'll try to get the distributor installed and fired up.
Old 05-29-2012, 05:37 PM   #191
Steves46
Steves46's Avatar
Vic, that really looks nice. The color blend is terrific! Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 05-29-2012, 06:38 PM   #192
Vic Piano
Vic Piano's Avatar
Steve, thanks, once everything is cleaned up and painted she should look fine... right now I just want her to run so I can have some fun with her while I wait for the floor pans from Bradley’s... Hoping to play again this Saturday, think you can cruise up? Vic
Old 05-29-2012, 10:58 PM   #193
Ken/Alabama
They are marked but its easy to get #6 and #9 mixed up so watch out for that.
Old 05-30-2012, 06:11 AM   #194
Vic Piano
Vic Piano's Avatar
Ken, I experienced my first screw up ever... LOL! I thought that the LZ marked the plugs like the Ford... Wrong... I had to retrace each plug wire as the LZ has odd numbers on left head and even numbers on the right head... Take away… If all else fails, read the instructions…
Old 05-30-2012, 07:15 AM   #195
TomT/Williamsburg
TomT/Williamsburg's Avatar
Reading the instructions is NOT in the instructions - or is it? I never read them .... until I'm in deep trouble - LOL!
TomT/Williamsburg is offline   Reply With Quote
Old 05-30-2012, 10:32 AM   #196
Vic Piano
Vic Piano's Avatar
This morning I cleaned up and inspected the distributor & coil, installed new gaskets, etc. Everything was working fine before I took it out of the LZ so I didn't want to disassemble everything to give it a super cleaning.
Old 05-30-2012, 04:12 PM   #197
VeryTangled
VeryTangled's Avatar
Amazing, keep it comin' Vic! So similar and yet so different!
-VeryTangled
VeryTangled is offline   Reply With Quote
Old 05-30-2012, 04:59 PM   #198
Vic Piano
Vic Piano's Avatar
-VeryTangled
Yup, I put everything back together and fired her up only to find that I must have crossed plug wires (maybe on #6 & #9) like Ken said. Oh well, looks like I'll have to pull everything out and try it again... I'll just keep repeating "I love my flatheads"...
Old 06-02-2012, 02:07 PM   #199
Vic Piano
Vic Piano's Avatar
Well, things are back to normal here at the garage...
Mike, Don, Steve and Cliff came over this morning and we fixed the crossed plug wires in the LZ... Now she's running like she should... Steve and I changed the oil in the '39 CS before the other guys got to the garage and after we fixed the LZ we put Don's '37 on the lift to give it a grease job.
After we finished with Don's car we all climbed into the Zephyr and went for (you guessed it) PIZZA... Life is good once more, now it's time to take the LZ for a nice drive.
Old 06-02-2012, 03:03 PM   #200
41ford1
41ford1's Avatar
I'll bet you're happy things are back to normal. The pickups and Don's '37 are looking good. Good enough to come north for a tour in August!!
