Old 08-29-2013, 10:41 PM   #1
flatheadz-forever
Default Re: Flathead project
very nice best of luck
flatheadz-forever is offline   Reply With Quote
Old 09-01-2013, 04:52 PM   #2
LSJUNIPER
Just finished adjusting the valves. I used one of those lifter wrenches from Speedway Motors. I had a difficult time at first, the tool kept slipping out of the holes in the adjustable lifters. Check out the pic, it shows what I put together as a tool to help hold the lifter wrench in place, simple but effective. Hope this will help any one else who may have the same prob with lifter wrenches slipping out of position...
LSJUNIPER is offline   Reply With Quote
Old 09-04-2013, 07:39 AM   #3
LSJUNIPER
Next, will be putting the pistons into the block.....
Old 09-12-2013, 11:43 AM   #4
flatheadz-forever
very nice any more updates?
Old 09-13-2013, 04:55 AM   #5
LSJUNIPER
Thank you flatheadz-forever, I should have some update pics early next week. I have to say that this project has been fun, I am learning a lot about these awesome motors.
Old 09-16-2013, 05:17 AM   #6
LSJUNIPER
Any recommendations on what type of sealant if any on the gaskets?
Old 09-16-2013, 04:55 PM   #7
flatheadz-forever
permatex black utv
Old 09-17-2013, 04:49 AM   #8
LSJUNIPER
Thanks
Old 09-18-2013, 09:49 PM   #9
flatheadz-forever
That stuff has never let me down
Old 09-23-2013, 10:42 AM   #10
LSJUNIPER
Some progress, sent the distributor to Bubba's Hot Rod Shop a few days ago and will be sending the water pumps out tomorrow to Skip's. Hope to drop the pistons in this week, will post pics when I do.....
Old 10-01-2013, 04:55 AM   #11
LSJUNIPER
Finally!!! Pistons are in the block!!
Old 10-01-2013, 06:17 AM   #12
Mart
Mart's Avatar
It looks like a nice tidy job!
Excellent work!
Mart.
Old 10-01-2013, 10:34 AM   #13
LSJUNIPER
Thanks Mart!
Old 10-07-2013, 04:37 PM   #14
LSJUNIPER
Received my water pumps from Skips today. One of the pumps has a warped pulley, not Skips fault, when I sent them I thought that the shaft was frozen on one of them but now I realized the pulley is touching the pump body. My questoin is how can a I change out the warped pulley for a new one?
Thanks
Old 10-08-2013, 03:23 PM   #15
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Distributor update.
When this project started i hoped that lsjuniper would use the factory helmet with the build. You just cant beat the helmet when set up and ready to go.
The picture shows the before and after , we have a very mad and dead spider , we named him Henry..
I have to replace the coil and hope to have a good used one to test tomorrow. The old coil had a shorted (open) primary coil and was junk....
Anyway heres todays update......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-09-2013, 04:56 AM   #16
LSJUNIPER
OMG!!!! I'm speechless?!?!?!?! Nice job!!!
Old 10-09-2013, 08:15 PM   #17
flatheadz-forever
very nice looks great!
Old 10-11-2013, 08:08 AM   #18
BUBBAS IGNITION
The old coil had a open primary winding, dug around in the parts box and found a like new Niehoff unit. Ran on tester runs good.
Should look good with the new engine etc.......
[email protected]
Old 10-12-2013, 06:14 PM   #19
LSJUNIPER
Can't wait to put that Distributor on the motor!!!
Thanks
Old 10-11-2013, 09:21 AM   #20
chuck stevens
chuck stevens's Avatar
Lsjuniper, I would be be checking for cracks before spending a lot of time on it. The bad ones are between the valves and the cylinders, the center cooling openings say big truck to me. If it passes the crack test, take the cam gear off to see if the bottom end will turn over, good luck Chuck S.
chuck stevens is offline   Reply With Quote
