For all the "non-believers"
We were lucky to find a rare once in a life time original Ford N.O.S. barn find gas line/ water outlet cooling device. This instrument will prevent vapor lock and also can be used to drop the temperature of your engine water outlet by a minimum of fifteen degrees. I must confess, I did try it on my '31 ford for a test and it works !!! I ran my car today with this fine device in 95 degree temperature with no ill effects from vapor lock or overheating.This unit was found in a trough that runs behind and below the cows (where all the Bullsh** falls) in a abandoned dairy barn in upstate New York. So in conclusion this should put the clothes pin theory to rest.
"Some Talk the Walk while others Walk the Walk" Last edited by Bob A.; 08-04-2010 at 09:31 AM. |
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
Say...Bob....you got any more of those...? I've called Bert's and Snyder's and while they've heard of them, neither of them has one. Is that a rare NOS model...or a repop...?
You realize you're sittin' on a gold mine, don't you....?
Freddie (Memphis) "...an opinon on everything...an expert on nuthin'..." I'm still doin' the rhumba, Baby...I just can't seem to quit. If momma catches us doin' the rhumba....momma would just pitch a fit. I can't help myself....it's much bigger than me. If I were you I'd hang on to a rhumba man like me...! |
bob
do you have phots of the outlet cooling device |
Pop was an old ford trained mechnic and worked onfords from the 30's- late 60's than went to caddys but on a trip in fla. with a 1953 flathead v8 {he bought it new cause they were not goinng to make them anymore} had vaporlock and he only had a bag of grapefruits..... yup he cut two partly in halve and put them on fuel line used friction tape[old time tape used like duct tape today for everything] to hold the heat sinks on and away we went, when we got to a store he purchased wooden closepins and put them on no more problems don't know why or how it worked but it did impress this 5year old!!!!!!!!!
Hmmm – I think the clothes pin topic has led your memory astray.
The grapefruit method was for the fuel pump. |
The only slight relevance to the clothes pins it to add the use of tinfoil wrapped around the fuel line shiney side out. It has always been told to me to uise the clothes pins to hold the tin foil in place. I doubt if it does any good unless used in direct sunlight. Some people get heat and light confused. I have never bought into this theroy at heat is heat and light is light and it is possible to have them independantly so I do not believe the laws of thermal dynamics support the use of the tinfoil in a darkened enviroment to block heat has any affect. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! Last edited by Rowdy; 06-29-2010 at 12:58 PM. Reason: spelling |
Here are a couple of examples from the archives of Popular Science.
My take on why it works . . .
It’s not the reflective aspect, it’s the conductive and heat transfer capacity of the foil that does the cooling. Hot water baseboard heat uses the same effect, and it’s semi hidden in it’s casing. |
I thought they were for DRYING YO' WET SOX.
Bill W.
That's the answer. You wrap your wet socks around the fuel line and clamp them with the clothespins, then let evaporative cooling keep the fuel from boiling.
Next thing you know someone will hang a contraption on the car window filled with excelsior and water, and call it air conditioning.
#13 |
There is a clothes-pin cure that absolutely works!
Do NOT try clipping them on the fuel line, that never worked for me. Here is what you do: Get a nice big sack of clothes-pins, all wood or spring type, your choice. When the car vapor locks, go and do your laundry. String a line and, using the clothespins, hang your laundry out to dry. It helps if you have some notched bamboo poles to prop up the line. After all is dry, folded, and the poles (optional), line and pins are put away, go start the car. Works every time. |
#14 | |
#15 |
Newbie here!
So roughly at what temperature range does vapor lock ocurr? Upper 70's? 80's and above? I do realize there's probably no set degree where vapor lock ocurrs. Just a wondering? Glenn |
#16 | |
Here in South Florida where the temps are often in the 90's this time of year and no one in our club has ever had vapor lock. It would be nice if there were a set of conditions that always caused vapor lock but there is none. some get it all the time, some never.
#17 |
You got it Doug in NJ: Wooden clothes pins work just like blood letting at the barber shop cured disease in the 19th century!! Nothing more, nothing less.
Steve Hanna, Polk City, IA |
#18 |
Back in the 50's my uncle had a '53 Ford V8. I was 4 or 5 at the time and I asked why he had all those clothes pins on his motor (must have been 40 or 50). He told me that was the only thing that would keep that car running in the hot Texas summer.
#19 | |
Fearless |
#20 |
A couple of wooden clothes pins work as well as touching your nose and spinning around three times before entering your car.
