03-30-2023, 08:31 PM | #21 |
Re: 37 ford 1.5 ton wheels
Oh boy, how do I do a short answer? Here goes. There were three wheel companies, and two rim companies. Budd, Kelsey Hayes, and Motor Wheel Corporation produced the wheels using rims sourced from either (or both) Firestone Steel Products Company or Goodyear. Budd and Motor Wheel products will have a five digit number stamped into the wheel somewhere. Generally concave inner face for Budd, or convex outer face for Motor Wheel. Kelsey Hayes have nothing/nada/zip. The K-H variety then have to be identified by measured offset and backspacing. I have a very complete library of old wheel and rim references and can generally look up the numbers and connect them to Ford numbers.
There will be differences in wheel offset and backspacing that naturally interplay with the rim widths when trying to build a set that are an exact or near match. I can on most look up the numbers that you find and give the comparative specs. I have found some wheels where the numbers are clearly stamped but are nowhere catalogued, but it’s rare. So let me know what you find. Stu
Stu McMillan Marmon-Herringtons |
04-01-2023, 08:46 AM | #22 |
Folks,
I think Redpond with the 32 truck is looking for some rims. Please check with him. He is in Bowling green KY. Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
03-29-2024, 02:31 PM | #23 |
looking for 6
03-29-2024, 06:28 PM | #24 |
drwoodruff
I have a small pile of 1935-1937 1 1/2 ton truck wheels. Most have some rust but you are welcome to visit and pick through to see if you can put together a set for your truck. I live just south of Washington, DC in Northern Virginia. Send me a PM if you are interested. Dave
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
04-07-2024, 06:37 AM | #25 |
I have a few I'd part with. Contact me if interested.
04-07-2024, 08:05 AM | #26 |
They are steel and white. If that’s any use to you. Local pickup only
I am building a 1939 1 ton express |
04-09-2024, 12:33 AM | #27 |
I restored a 1947 COE about 12 years ago, and my wheels were stamped Firestone on the inside.
