01-21-2024, 06:26 PM | #1 |
Head gaskets v8
How big is the piston bore before having to use overbore gaskets?
Thanks |
01-21-2024, 06:57 PM | #2 |
Re: Head gaskets v8
I’m thinking.080
01-22-2024, 07:41 AM | #3 |
Re: Head gaskets v8
thanks Ken
01-22-2024, 10:04 AM | #4 |
Re: Head gaskets v8
I think Ken has it about right. If I was .080 or larger, then go to the big-bore versions. Also, I tend to sue the GraphTite style gaskets on street engines from Best Gasket.
01-22-2024, 10:37 AM | #5 |
Re: Head gaskets v8
What B&S said x2.
01-22-2024, 10:49 AM | #6 |
Re: Head gaskets v8
01-22-2024, 01:47 PM | #7 |
Re: Head gaskets v8
I've seen a lot less electrolysis with the composite style versus the copper-sandwich types.
Now, if you are doing other things to prevent electrolysis, then maybe not an issue. I also like the Cometic MLS gaskets - really nice product, but expensive. One nice thing is that they are available in many different gasket thichnesses. Important! You must have the correct (pretty smooth) surface finish on the decks and heads to run MLS gaskets and not have coolant weeping. |
01-22-2024, 09:05 PM | #8 |
Re: Head gaskets v8
I use copper on all.
I run 50/50 anti freeze on the street with 1 can of Bars Leaks. I run straight water on the track with 1 can of Bars Leaks. I have never noted any electrolysis etching. |
01-22-2024, 10:13 PM | #9 |
Re: Head gaskets v8
Thanks to all!
01-22-2024, 10:35 PM | #10 | |
Re: Head gaskets v8
Why the Bars Leaks? in my past experience Bars Leaks was a good way to block radiators. |
01-22-2024, 10:40 PM | #11 |
Re: Head gaskets v8
01-23-2024, 09:06 AM | #12 |
Re: Head gaskets v8
while we are on water pumps wheres a good place to buy rebuild kits for pumps?
01-23-2024, 09:21 AM | #13 |
Re: Head gaskets v8
Works well for me with no radiator problems.
Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source for the 1932 thru 1953 Flathead Ford |
01-23-2024, 09:23 AM | #14 |
Re: Head gaskets v8
Is this the stuff we are talking about or the old fashioned tablets?
https://barsleaks.com/product/rhizex...top-leak-1199/ |
01-23-2024, 09:25 AM | #15 | |
Re: Head gaskets v8
Skip Haney Punts Gorda Florida. [email protected] 941-637-6698 He’s been doing it for many decades with high volume impellers.
01-23-2024, 09:30 AM | #16 | |
Re: Head gaskets v8
Glenn
01-23-2024, 09:59 AM | #17 |
Re: Head gaskets v8
Generally speaking, as long as your radiator is clean in the first place, it won't cause you any trouble, It gets a bad wrap from people who have a compromised radiator and then dump stop leak in it, well guess what, it will plug the radiator up then. On the other hand Trying to run a flathead with a dirty radiator isn't the best idea in the world anyway! LOL
01-23-2024, 03:29 PM | #18 | |
Re: Head gaskets v8
01-23-2024, 03:50 PM | #19 |
Re: Head gaskets v8
01-23-2024, 09:44 PM | #20 |
Re: Head gaskets v8
Thanks Glen I talked with him
