11-30-2023, 07:46 PM | #1 |
41 front spring
Looking at a 41 front end over on the HAMB and it appears when the front end is loaded the front shackles will be pointing out at the bottom at a 45 degree angle in stead of in at the same angle. Guy over there says that's the way the 41's were designed. Right or wrong? Thanks
11-30-2023, 07:58 PM | #2 |
Re: 41 front spring
Most 41's I have worked on look like you describe, outward shackles. In 42 they added the panhard bar to eliminate the sway. All the 40's I have worked on are 45 degrees inward.
11-30-2023, 08:35 PM | #3 |
Re: 41 front spring
On my 42 they are tilted in towards the engine but slightly...
11-30-2023, 09:22 PM | #4 | |
Re: 41 front spring
Not an expert on '41s but I do own one. To the best of my knowledge the suspension is original. Heard a lot about '41s: transition year, odd duck, etc. Been told I have a hash of mismatched parts but IMHO, they're factory correct. My shackles point out at the bottom. |
11-30-2023, 11:02 PM | #5 |
Re: 41 front spring
On our '41 we had the spring eyes rerolled so shackels were at a 45 deg angle in. helps a lot on handelling. tried to add a panhard bar but it made the front end extremely stiff. believe panhard was fighting the roll bar swivel operation.
12-01-2023, 05:42 AM | #6 |
Re: 41 front spring
12-01-2023, 11:33 AM | #7 |
Re: 41 front spring
The reason for the outward cant on your shackles may be that the spring has completely lost its arch, and as a result, spread out. The '41 front spring is an odd duck, and you may have a hard time finding a correct replacement. I had no luck with that.
My '41 with original springs has the shackles 45 degrees inward. That geometry provides some resistance to body roll in a turn. As the side force occurs in a turn it forces the shackle on the outside of the turn to a more vertical angle, raising the body on that side. Thus the anti-roll response. When I installed a new reverse-eye spring to lower the front a bit, the stock shackles were actually near flat (too short); also not good due to harsh ride and excessive side forces created on the spring mounts. So I modified 4" shackles to get the right angle. The ride and handling are now very good. |
12-01-2023, 01:56 PM | #8 |
Re: 41 front spring
Both of mine are canted just slightly outward. The cars sit up high as originally designed . My springs have plenty of arch .
12-01-2023, 01:57 PM | #9 |
Re: 41 front spring
I have a pic but am too challenged to post here , if someone wants to see it , I can email .
Gary |
12-01-2023, 07:41 PM | #10 | |
Re: 41 front spring
12-02-2023, 12:20 AM | #11 | |
Re: 41 front spring
12-02-2023, 01:22 AM | #12 |
Re: 41 front spring
12-02-2023, 01:31 AM | #13 |
Re: 41 front spring
Looks like Eaton Detroit would sell me a new one for $475.
12-02-2023, 06:23 AM | #14 |
Re: 41 front spring
Ive got a few front and rear 1941 springs.unfortunately I live in s Florida. You can have one free but the shipping is probably not worth it .
Gary SoCalCoupe , I sent you a pm |
12-03-2023, 05:53 PM | #15 |
Re: 41 front spring
The front spring in an early production '41 I had was so flat that if you turned full lock, the shackles would have shredded the inside of the front tires. I bought and installed a reversed eye spring from Speedway to solve the problem.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
12-03-2023, 09:04 PM | #16 |
Re: 41 front spring
The spring perches centerline to centerline measurement on 35 - 40 Ford is 42 3/8". On 42 - 48 it is 42 1/2". I measured that distance on my early model year '41 and it is 40 3/4". The Posies 2100 reverse eye spring I bought supposedly for a '41 was designed for 42.5" perch distance, and way too wide. I exchanged it for a Posies 2037 40L, designed for perch distance or 39 3/8". With that, the stock shackles were too flat, so I bought some 4" lowering shackles and drilled and filed holes at a distance that gave me the 45 degree shackle angle I was looking for. Versus the tired flat stock spring, the reverse eye got me less than a half inch lower, but the stance is fine. The ride and handling are great.
12-04-2023, 11:42 AM | #17 | |
Re: 41 front spring
12-05-2023, 02:00 PM | #18 |
Re: 41 front spring
Except for my '41, which I measured myself, the numbers came from the Posies catalog. And the measurements are axle spring perch centerlines, not unloaded spring eye to spring eye.
