I am rebuilding my first Flathead. Please don’t tell me to leave it up to the pros. That's boring and there are none around me. Anyway, below are the specs and my first question as I start to put this together. I will use this thread for the random questions I have along the way rather than starting a new thread every time.
Car 40 coupe, stock drivetrain, upgraded brakes and suspension. Engine Specs 40 block 4” crank 3 3/16 pistons (stroked crank taken into account) 8ba rods Isky max 1 cam Adjustable lifters with holes drilled for adjusting Edelbrock aluminum heads Dual 97’s on an edmunds intake My first question is, is it ok to use the steel crank gear up against an aluminum cam gear? Somewhere I read this was not ok? Please confirm.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ Last edited by busmania; 08-09-2023 at 06:22 PM. |
French motors use steel crank gear and aluminium cam wheels. So I would say it is ok.
Regarding the gears. yes it is absolutely OK to use. Unless you want to get a specially made gear set, your choices are steel crank and aluminum or fiber cam gear.
If you haven't already, I would strongly urge you to get the block completely checked out by you or someone who knows what to look for before you proceed. By checked out, I mean: 1) Completely cleaned and the water jackets cleaned off all crud 2) Pressure tested. If it passes pressure testing, move to set three. 3) Magnifluxed Until you do these three things to the block, there is no guarantee the block is good and you could be spending a lot of time, effort and money for naught. |
#4 | |
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
drill for adjustable lifter, use them. check for clearance on the crank to block-area outside block rails-sometimes you will need a little relief there
Gramps |
Ford used fiber cam gears with steel crank gears without any problems.
My 1953 Ford V-8 still uses them both. |
Yep. Did that too (drilled for lifter).
#9 | |
I’ll have hundreds of questions. Most which will be answered by searching internet. The ones I can’t find I’ll come here. I’m not afraid to ask!
If using the 4" merc crank, I would also use some 8ba rods since you have 2 oil holes per journal, and the bearings are cheaper and easier to deal with. Merc crank needs merc pistons too, if you didn't know that.
Also, be aware that some 8BA rods have squirt holes and some do not. The early 8BA's used the splash system of oiling and didn't have the holes. Later 8BA's did.
#13 |
Oh yeah, I’m using 8ba rods. I updated my original post (and will do so as people mention things I forgot to say).
Also using correct pistons as recommended by van pelt. When I ordered months ago we actually had to correct that before shipping so I know we discussed it. Will post photos of rods later today. I should also note that my machine shop would not do any machine work until I had all parts ordered and in their hands, including bearings, rods, pistons, etc. They wanted to have them on hand to make sure they would work with the machine work they were doing. They told me what sizes to buy after initial inspection then I bought from van pelt then the machine shop did the work.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ Last edited by busmania; 08-09-2023 at 05:13 PM. |
#14 |
Just an FYI...Before beginning assembly, check to make sure the rear cam bearing is lined up so the fuel pump pushrod will go by it and not hang up on the edge. Happens a lot!
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#15 |
Good point. Do you mean the hole of the bearing not being centered over the hole in the block? The bearing was centered perfect over the hole as far as I remember. I remember looking at it because someone else mentioned that to me recently. There was no bearing overhanging the hole but I will verify next time I unwrap the plastic that keeps it clean between sessions.
#16 |
The hole through the rear cam bearing that the fuel pump push rod drops down through. I got that off just a bit on a recent assembly (it looked ok, but push rod wouldn't assemble). Didn't want to disassemble everything, got lucky and my friends were able to use an old cam bearing and a small port-a-power between the engine stand and the rear of the motor to ease the cam bearing forward on the assembled engine. I don't recommend going through all that.
#17 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#18 |
It sounds like you're gonna do a real good job. Fun, ain't it?
#19 |
Do you have the more modern rear seal plates? Your engine probably came with what are known as labyrinth seals in the rear mains. You'll want to replace the stock seals with the later seal plates and rope or graphite seals. You can chat with VanPelt about this. I'd run the GraphTite gasket kit - with the composite head gaskets (not the copper ones). Also, pay particular attention to the instructions for the rear main seal - and the installation of the "roll-pin" to keep their seals from potentially spinning.
Also, make sure that when you test fit the replacement seal plates that they DO NOT stick up above the deck or ream main surface. I've had to trim some of them on my mill - to make sure the rear main cap would seat all the way down. I'd replace the 1940 oil pump with the later 49-53 pump and buy the special bolt-on pickup from Speedway. Also, stretch the front oil-pressure relief spring about 1/4 to 3/8" so that the new pump's pressure relief spring/plunger becomes the "boss". Best of luck! |
#20 |
Here is an example of a conversion kit for the mains - from Reds. VanPelt will probably have the same thing - at a better price:
https://reds-vintage-parts.com/store...e-1936-to-1942 |
