05-27-2013, 09:10 PM | #21 |
Re: what type oil and gas for flathead
Now Ken. You know that "Carters Little Liver Pills" had to be dropped as the F.D.A. said there was nothing in them that did anything to help liver function. So they just dropped the liver and call them Carter's Little Pills. No telling what they claim that the pills are good for. Maybe like Hadacol. LOL
05-27-2013, 11:33 PM | #22 | |
You will see things like "API SG or CJ" on the oil container, that means: API = American Petrolium Industry SG = Spark ignition (for gasoline engines), grade "G" CJ = Compression ignition (for diesel engines), grade "J" The second letter is the grade designator, in alphabetical order, and later = better. I know I've said all of this before but I will say it again every time someone recommends that oil formulated for diesel engines be used in our flatheads.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
07-23-2021, 03:58 AM | #23 |
this has gone around so many times its dizzy 1 OIL a good quality oil is whats needed grade/ brand/viscosity talk to your local supplier as you dont want a 50w in Alaska or a 10 w in Mexico Detergent or mineral to me thats personal and often depends on engine internal condition .2 Fuel you got to remember that leaded didnt exist when they where designed ok alcohol that's different but you can rebuild certain parts with alcohol resistant parts and work well with ethanol fuels LOOK at what you have and choose to your needs and you wont have to much trouble
05-10-2022, 03:42 PM | #24 | |
05-10-2022, 05:51 PM | #25 |
My routine is, for gas, non ethanol with MMO and lead substitute. For oil, I roll with Shell Rotella, largely because I have it on hand for diesel machinery, so no particular magic.
No job’s done ‘til it’s all done |
05-10-2022, 08:55 PM | #26 |
Straight weight oils are fading away. |
05-11-2022, 11:02 AM | #27 | |
When I was young working on the my Mustang with an engine full of sludge. My neighbor said whatever you do don't put detergent oil in it because it will break all that stuff loose and plug op your oil pick up screen. He probably was correct. So for years that is the theory I used on detergent versus non-detergent. If he engine was clean inside then I ran detergent and if was full of sludge I ran non-detergent. But then I bought, lawn mower and a pressure washer and both said to "only" use non-detergent 30W oil. That got be wondering, why if its new inside do they want me to use non-detergent oil. I had a hard time finding the answer but here it is. It has to do whether the engine has an oil filter or not. If it has oil filter the detergent keeps the dirt suspended in the oil where it can flow to the filter and be removed. Without an oil filter you don't want the dirt flowing in the oil you want it settle into the bottom of the oil pan. So if you "do not" have an oil filter run non-detergent oil I thick the early Ford oil change intervals was something like only 1000 miles. If you don't have a filter that is probably a good idea. On my flat tappet Mustang engines I always ran diesel Delo 400 15W40 because the diesels have extra zinc the zinc to keep from wiping put the rod bearings because of the high compressios' pressure exerted on them. I was going to run the same oil in my flathead, that's if I ever finish one. If you have flathead without a filter I don't know if their is a readily available non-detergent oil with the zinc. The problem I have is I walk into an O'Reilly's or an AutoZone and they are in such competition with each other they carry the exact same thing. If its not a fast moving item they don't have it. They have run all the old-time parts stores out of business. They even ran our Napa out of business. We only ran Delo 15W40 oil at the phone company on 400 vehicles. Didn't matter if it called for 10W-30W, 5W-30, synthetic they all got 15W-40W Delo 400. We had some larger diesel trucks that required the Delo 400 oil so everything got it. They bought their oil in bulk, 500 gallons at a time that was held in a large above ground tank. Then it was pumped through the shop to the overhead lube reels. They refused to stock every kind of oil the factories recommended. In 30-years we never lost one single engine because of bearing failure. Some had over 300,000 miles on them When did lose one which was rare it was because it ran out of oil, it was the driver's responsibility to check the oil, If they screwed up we billed the engine to their department. Also, most engines were Dodge 5.2s, 5,9s, Chevy 350s, Ford straight sixes, 302s, 351s 429s 460s and I never had a single lifter dish on a flat tappet cam. So I know from following hundreds, maybe even thousands of engines with a combine million and millions of miles on thenm that the Del 400 diesel oil is a great oil. There is absolutely no other oil I would trust. MY newer pickup takes 0W-30W synthetic. I know the engine clearances are designed for that thin oil. I'm not the "cheap" phone company so I use what the factory recommends on my modern vehicles but on the vintage ones it's only Delo 400. |
05-11-2022, 11:08 AM | #28 |
Flathead Fever: Thanks for posting that oil filter and oil info. Very interesting.
