12-14-2021, 10:16 PM | #1 |
39 engine colors (Assume 60&85HP are the same)
I know the engine is green, but who sells paint that is closest to original? Hirsch?
Are water pump and crank pulleys black? Is transmission green as well as engine? (Mine is/was red which I'm sure is not correct.) Is oil pan black? Are 60HP head nuts just average hardware store nuts? They look pretty much the same. I'm trying to get everything correct on the 60HP I'm cosmetically restoring. Thanks Lawson
Life is like a roll of toilet paper. The closer to the end, the faster it goes. It is better to be seen, than viewed. "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". Last edited by Lawson Cox; 12-14-2021 at 10:31 PM. |
12-15-2021, 12:00 AM | #2 |
Re: 39 engine colors (Assume 60&85HP are the same)
Need the V8 Ford Club books! I get my Green from Bert's Model A parts. Newc
12-15-2021, 12:11 PM | #3 | |
Thanks
12-15-2021, 02:41 PM | #4 |
[QUOTE=Lawson Cox;2085556]I know the engine is green, but who sells paint that is closest to original? Hirsch?
Are water pump and crank pulleys black? No, they are green. The end of the pulley shaft is bare metal. Is transmission green as well as engine? Yes, but keep in mind the case was painted prior to assembly. Thus, no paint on the milled surfaces. (Mine is/was red which I'm sure is not correct.) Is oil pan black? Gloss. Are 60HP head nuts just average hardware store nuts? They look pretty much the same. No, the authentic nuts are cadmium plated - not zinc as you'd find in a hardware store. They also have a definite flat on each side. Also, you need to place a flat washer between each nut and the cylinder head. I'm trying to get everything correct on the 60HP I'm cosmetically restoring. No paint on gaskets nor any milled surface of the block. Head studs are near a stain black in appearance.
12-15-2021, 02:57 PM | #5 |
ALSO, the head nuts are what is called a "Heavy" Pattern Hex Nut, not a "Finished" pattern Hex Nut which is A) one wrench size smaller than a "Heavy Pattern" AND B) "Finished" pattern is what "most" hardware stores carry!!!
12-15-2021, 03:25 PM | #6 |
12-15-2021, 06:01 PM | #7 |
Your engine was originally equipped with aluminum heads. Steel was a replacement part.
12-15-2021, 07:49 PM | #8 | |
What is the correct nomenclature for the little pointed rubber "nose cone" on the 60 water pumps? Do you know if that item is being reproduced? Mine are sort of cracking. Any ideas on how to "repair" them so they look good?
12-15-2021, 08:02 PM | #9 |
If you watched the movie, "The World's Fastest Indian" Burt Munroe uses black shoe polish to fill the cracks in his tires, probably Kiwi brand.
Ps: a great movie for motor heads. Last edited by Zeke3; 12-15-2021 at 08:06 PM. Reason: added Ps. |
12-15-2021, 10:29 PM | #10 |
CG Ford has the correct paint for $7.99 per can. I just sprayed my engine and one can is all you need. I bought three, I guess I’ll paint some stuff green around the house.
12-16-2021, 08:52 AM | #11 | |
12-16-2021, 09:57 AM | #12 |
Is the flat washer a normal steel or cad. like the nuts? The engine I bought has all the nuts but no washers. I haven’t done final assembly yet and it just looked to me like it should have washers.
Sent from my iPhone using Tapatalk |
12-16-2021, 10:29 AM | #13 | |
To be clear, washers were incorporated upon aluminum cylinder heads - not cast heads.
12-16-2021, 11:07 AM | #14 |
Gotcha. Thanks Kube.
12-16-2021, 11:39 AM | #15 |
Ok then I’m fine as is
12-17-2021, 11:14 AM | #16 |
Ford only changed engine color so as to be able to identify the new 239 engine from the 221 since they both looked a lot alike.
12-17-2021, 11:38 AM | #17 |
That makes sense.
12-17-2021, 02:07 PM | #18 |
I'm finally able to get down to the fun work on the 60HP, de-greasing it and removing forty-eleven coats of many colors of paint. I think, with a coating of that many colors I'll name it Joseph. And yes, I'm truly having a blast.
