04-02-2021, 04:25 PM | #1 |
56 dash question, extra hole?
Got the dash out and cleaning it up for primer. I now have a extra hole in the dash where the ignition originally went. I am going with a steering column that has the ignition on the column so have no need for the dash ignition. Question is what do you do with the old ignition hole? I could add another lighter power port but two would look dorky. I could cut it out and fill it in but that is a fair size chunk to cut out. Anyway any ideas? Thanks
04-02-2021, 05:55 PM | #2 |
Re: 56 dash question, extra hole?
When I bought my 58 Chevy wagon, it had dealer installed a/c in it, with an air vent at each end of the dash, down low. Most of the a/c was missing, so I sold what was left. I welded up the holes, working upside down (the dash doesn't come out). That was fun, but you can't tell it. The holes were very large.
04-02-2021, 06:19 PM | #3 |
Maybe a cover as shown below? Paint To Match?
They were commonly used back when. |
04-02-2021, 06:33 PM | #4 |
I used plugs like Kultulz shows above. NAPA had flat black or chrome to chose from.
04-02-2021, 09:27 PM | #5 |
Put the original switch and trim ring there for looks, just not connected to anything. It could confuse somebody trying to steal the car.
04-03-2021, 11:00 AM | #6 |
04-03-2021, 11:10 AM | #7 |
Now you know I would be the first MOE-RON to try and figure out why a two-sided key will not fit the old cylinder ...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
04-07-2021, 07:17 PM | #8 |
Add a choke cable there.
Matt 24:36-41 |
04-07-2021, 07:27 PM | #9 |
Use the key on the column for ignition and install a push button in the dash to engage the starter.
04-07-2021, 10:14 PM | #10 |
get a knob that matches the rest in the dash and epoxy it to whatever you put in the hole and it will blend in with the rest.
04-08-2021, 10:43 AM | #11 |
Thanks for the ideas guys.
