12-05-2020, 12:14 PM | #1 |
55 Ford Data Plate mounting???
Putting my 55 Ford Ranch Wagon project back together and ran accross a little problem , maybe somebody can check their Ford and give me the answer. On the data plate , there are two sets of predrilled holes to attach the plate to the body. ( drivers side door body below windshield side.) One set results in the data plate being mounted horizontal to the ground. The other set results in the data plate being at about a 35 degree angle to the ground. Which would be the original and correct mounting holes???
Probably should have just taped off the plate rather than removing it. Well that was better than two years ago , and I just have plain forgotten which way it was mounted. Thanks in advance for getting me straightened out on this. Steve |
12-05-2020, 12:26 PM | #2 |
Re: 55 Ford Data Plate mounting???
Pic of my 56, think they are he same. Have cleaned it up since pic taken. lol
12-05-2020, 01:08 PM | #3 |
Horizontal, not at an angle.
Original style 'factory' replacement rivets are available from several sources. Example, https://www.classictbird.com/Data-Pl...oductinfo/800/ |
12-05-2020, 01:15 PM | #4 |
Thanks Guys....horizontal it is!
12-05-2020, 06:13 PM | #5 | |
12-05-2020, 07:33 PM | #6 |
12-05-2020, 07:51 PM | #7 |
Looking at post # 2 photo, it appears that the flanged end of the rivet will be on the outside when installed and a tool has to pull the spherical portion out to expand and catch the body. I could be wrong.
12-05-2020, 08:04 PM | #8 |
Yes the flange is to the outside to hold the data plate on. I believe you insert the rivet into the data plate and door post holes (or firewall for T-Birds) then when it's in position push or tap in the center dome, which expands the back side of the rivet, fastening it in place.
12-06-2020, 10:19 AM | #9 |
I would suggest to have extra rivets on hand. They are very soft and can push through very easy.
12-07-2020, 08:41 AM | #10 |
Of the several I have rebuilt I found the "rivets" appeared to have been set with a center punch type of tool. All four cars have a dimple in the middle of the dome. As a result I have used a center punch to set the rivets. As stated go easy, they are softer then butter.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
12-11-2020, 09:41 AM | #11 |
Thanks ....I ordered those rivits today. I'll let you know how they work.
steve |
