05-18-2020, 11:12 AM | #1 |
Arcing Brake Shoes
Looking for someone to arc my new brake shoes in Southern NH or Mass.
Any help would be appreciated. Thanks |
05-18-2020, 11:20 AM | #2 |
Re: Arcing Brake Shoes
Be sure to also ask at your local Model A and Early V8 Ford Clubs. I ended up sending mine back to the manufacturer.
Charlie Stephens |
05-18-2020, 09:47 PM | #3 |
Try a truck brake shop. They still arch shoes and might be able to do yours.
Mike
05-19-2020, 07:41 AM | #4 |
Location, location, location. Where are you?? There may be someone down the street from you who could do it.
I don't understand why people are reluctant to post their location?? Paul in CT |
05-19-2020, 07:50 AM | #5 |
I did mine for my AA the redneck way. I used a bench belt sander. Trial and error. Took small amounts, try fit in drum, fielders gauge, try fit, repeat...
05-19-2020, 07:55 AM | #6 | |
That's the way I did mine. I imagine after a few hard stops whatever small high spots there are will be gone. |
05-19-2020, 08:26 PM | #7 |
David, Check your PM (Private Message folder).
Bob Bader |
05-19-2020, 08:58 PM | #8 |
i can do it for u dave i am in conn by bradley air port 10.00 per shoe 8608835290
05-20-2020, 06:49 AM | #9 |
You could line the drum with sand paper, insert shoe and carefully rub.
05-20-2020, 06:52 AM | #10 | |
I saw someone posted that here once and others said it wouldn't work perfectly because you are arcing it to the radius of the drum minus the thickness of the sandpaper. It still seems like a clever idea to me. I don't think the thickness of the sandpaper would make a huge difference. |
05-20-2020, 09:17 AM | #11 |
i have a friend(in his eighties) here that has worked on a's most of his life. he has a way
to arc the shoes in a press to make them fit the drum. in fact he gave me his old brake shoe grinder, never uses it. just bends the shoes til they fit the drum radius. |
05-20-2020, 03:01 PM | #12 |
05-20-2020, 05:47 PM | #13 | |
Exactly right. |
05-20-2020, 05:48 PM | #14 | |
Many years ago when Macs was still Lockport they said thats how they did them. Stuck the shoe in a press and 'warped' it. |
05-22-2020, 09:39 PM | #15 |
