Old 04-01-2020, 05:58 PM   #1
slantback37
slantback37's Avatar
Default headliner bows
how many headliner bows are there for a 1937 tudor sedan. When I bought the car they were on the floor. Are they numbered at all so I can find the right locations?? Thanks
slantback37 is offline   Reply With Quote
Old 04-01-2020, 07:31 PM   #2
1937sedandelivery
Default Re: headliner bows
There are 5 headliner bows for the Tudor. In the Body Parts List book, it indicates they are all the same part number, from which I conclude they are all the same length. It does surprise me though. I don't believe they are numbered but could be wrong.
gregg
1937sedandelivery is offline   Reply With Quote
Old 04-02-2020, 09:33 AM   #3
slantback37
Thanks
Old 04-02-2020, 09:40 AM   #4
TJ
TJ's Avatar
Not sure about a 37 tudor, but I think there may be two small wire bows (bent in a C shape) that go in the rear corners. They tuck into a slot that is next to the rear window and the other end goes into a slot just behind the quarter window.
Old 04-02-2020, 01:41 PM   #5
swoopNZ
MEMBER EMERITUS
5 for the 37 Tudor
#1 78-705024
#2 78-705025
#3 78-705026
#4 78-705027
#5 78-705028
#1 is the same for a fordor
From the 1937 ford Body parts list
swoopNZ is offline   Reply With Quote
Old 04-02-2020, 02:11 PM   #6
1937sedandelivery
Originally Posted by swoopNZ View Post
5 for the 37 Tudor
#1 78-705024
#2 78-705025
#3 78-705026
#4 78-705027
#5 78-705028
You are absolutely correct. It makes sense that each one is a different length. I mistakenly was looking at the screw p/n, duh!
gregg
