10-24-2019, 09:12 PM | #21 |
Re: No compression all cylinders
I looked at the body for something to salvage..but no dice,ended up buying the chassis..fresh engine with nice babbit,transmission and rear end excellent,mitchell OD,pro built backing plates with woven shoes and cast iron drums,front axle tight,f100 steering box..all for half of what a new mitchell costs.When I tore it down and saw what I had I was giddy as a school girl..
10-24-2019, 09:54 PM | #22 |
This is my guess also.
10-25-2019, 06:38 AM | #23 |
I'm sure you have checked, but I will ask anyway, is your compression gauge operating properly?
10-25-2019, 07:23 AM | #24 |
Don't spend a lot of time "guessing". You're going to tear it apart anyway, right?
If you don't plan om tearing it down then you can spend a lot of time and money chasing the "gremlins"... Either way, "Enjoy the adventure"... Chap |
10-28-2019, 04:54 PM | #25 |
Took the valve cover plate off today and saw 4 sticking valves. Took the head off and with a little persuasion got all valves freed up and moving. One stuck valve in each cylinder will certainly give zero compression in all 4 cylinders
10-28-2019, 05:07 PM | #26 |
10-28-2019, 06:27 PM | #27 |
I guess the valves really weren't going up and down.
