03-01-2019, 05:28 PM | #1 |
Camden Supercharger
Is anyone running a Camden Supercharger or even just have one?
I'm running one in my 35 coupe and I wanted to compare notes. I get around 4lbs of boost at 4000 rpm with the pulleys that came with the set up. Thanks Joe |
03-02-2019, 04:07 PM | #2 |
Re: Camden Supercharger
No one?!
03-02-2019, 04:34 PM | #3 |
Have never see one. On a flathead? Got pics. Mike
03-02-2019, 04:45 PM | #4 |
Camden blower
03-02-2019, 05:04 PM | #5 |
I remember your thread from back in 2014. Most folks go for the Roadrunner engineering Weiand kits or H&H Flathead's Navarro 471 or SCoT blower set ups. The Camden doesn't garner a lot of attention in the flathead performance area since they are advertised for smaller displacement engines or rotary engines for Mazda cars. It's kind of out of the Ford Barn theme of things too. The HAMB may have some other folks that have them.
03-02-2019, 07:58 PM | #6 |
They had Chevy small and big block kits, Buick, Chevy and Ford V6 kits but the new owners concentrated on small four cylinder stuff.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
03-03-2019, 10:10 AM | #7 |
Yes, I believe it was in 1990/91
03-03-2019, 10:14 AM | #8 | |
03-05-2019, 08:52 PM | #9 |
I believe Speedway used to sell the Camden supercharger in a kit for Flatheads years ago.
03-06-2019, 09:54 PM | #10 |
Joe while i have no experience with the camden blower I remember years back when they were first offered I spent time looking them over. Since your getting 4 lbs of boost at 4 grand at this point thats not to bad. To gain more boost the drive ratio needs to be adjusted so going down 1/4 inch in diameter on the blower would give you another 2 to 3 pounds. If going smaller on the upper pulley is not possible doing the same by increasing the lower pulley diameter would also give you more boost.
Something to remember about the Flathead port design seeing high boost readings is not truly an indication of the pressure the cylinder is seeing. The poor port design is actually a choke to the boost so the high readings are caused by a backup of flow. Back when i ran my 671 GMC combination I would always see over 20 pounds of boost with no ill effects to the engine even in street driven form as long as a good octane gas was being used when the boost was getting high. That old reliable 671 combination is waiting for a new owner complete bolt on for the Flathead as some say go big or go home. LOL Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-07-2019, 04:23 AM | #11 | |
Thanks again, Joe |
03-07-2019, 08:27 AM | #12 |
The Magnason blower kit for the Flathead uses an Eaton ny-pass blower. On My friends 294 engine it produces 235 hp at 4500 (red line) with only 3 1/2 to 5 lbs boost. Blower comes in at WOT around 3000. The engine could probably produce more power, however the cost of building it doesn't justify blowing it up just to see how much power it could make. Runs great on the street driving a C4 auto into a 3.08 rear giving great gas milage in cruise.
03-07-2019, 08:46 AM | #13 | |
joe, I'm in the process of building my own eaton based unit. joe abbin has a nice formula for determining rough boost levels. i would input your current setup and run the numbers to see how accurate they are to your setup then modify his "fudge factor" number to match your setup. after that play with the target boost numbers to get you a ratio that will work for you. I don't know who I would trust more with a boosted motor, the guy who builds and dynos them and literally wrote the book, or the guy who just broke his own record with a blown flathead on the salt AGAIN..... we really do live great times to have this sort of blown flathead experience at our fingertips!! here is Joe's formula copy and pasted from www.roadrunnerengineering.com There is no simple, accurate relationship for estimating boost and pulley size because of all the variables involved. Roger Huntington in his 1950 book Souping the Stock Engine had a reasonable estimating equation: R = (A x D)/(K x V) where, R is the blower drive ratio (crank pulley dia/blower pulley dia) A is the desired manifold pressure in atmospheres (14.7 psia = 1 atmosphere) D is the engine displacement in cu.in. V is the Roots blower displacement in cu.in./revolution K is a constant determined by experience. I use 1.8 . For example, assume a 276 cu.in. engine, a 142 cu.in./rev blower (e.g. Weiand 142) and 6.6 psi boost, A = (14.7+6.6)/14.7 = 1.45 R = (1.45 x 276)/(1.8 x 142) = 1.56 Not too bad compared to 1.5 in the example on page 49 of Blown Flathead. I use Engine Analyzer Pro software for more accurate estimates. A more complete engine analysis can be done using the Analysis Worksheet included on this web page. |
03-07-2019, 03:14 PM | #14 |
Hi Joe
I would use Joe Abins formula for a guesstimate on what you would get like Revkev6 has written. However i would not be to concerned with the potential of 8 to 10 pounds of boost on your engine. Revkev I not only reset our record on the salt but also have many thousands of miles on the roads with three different blower combinations. Average HP on the street over 300. All trouble free miles even when using the options. that being the loud pedal. Returning again to the salt this year to see if more speed can be added to my top speed to date with my old trusty valve in block Flathead Ford V-8 block. More fun to still to be had i hope LOL Ronnieroadster
03-07-2019, 05:53 PM | #15 | |
03-07-2019, 06:00 PM | #16 | |
Thanks again, Joe |
03-07-2019, 06:01 PM | #17 | |
Thanks for your response, Joe |
03-07-2019, 07:56 PM | #18 | |
03-10-2019, 07:52 PM | #19 |
A sidebar, but possibly of interest, John Camden built his superchargers here in Austin. I remember when he developed the kit for the flathead. He is still around, super smart innovative engineer, in his 80s now. As a kid he worked on Model Ts moving up into VWs that he and buddies would remove the bodies from and race around. He worked as a mechanical engineer for the GM institute in the 1950s and GM invited him to work on the design of the early 6 cylinder Corvettes, worked on a '55 Chevy that set a Pike's Peak speed record, raced and crashed a '56 Corvette at Sebring, ran a speed shop in Utica, NY, where he built and installed supercharged small block Chevy's in small foreign cars, designed industrial chain drives for Borg Warner, designed a propeller reduction gear for a 460 Ford mounted in an airplane, got into aviation design at Mooney Aircraft in Kerrville, leading to working as chief mechanical engineer for a project at Learjet, was partners in building a car called the Cumberford Martinique, after which at some point he began developing his supercharger, and I'm sure there's lots more to his story. He is retired and the last car that I know he built was a soap box derby car that his wife drove to a win at the "adult" soap box derby races in Marble Falls, TX, also winning "Best Of Show", in 2016. He's a true hot rodder!
03-11-2019, 03:46 AM | #20 | |
