04-17-2018, 09:17 AM | #1 |
model a /c4 automatic
What experience has anyone here had with this combination.
04-17-2018, 10:17 AM | #2 |
Re: model a /c4 automatic
Use the "search" function and you will find a lot of information. If it is being done for medical reasons people are generally 100% in favor of doing it. Other reasons don't get much support. If I had a need I would use a modern 4 cylinder engine that came with the modern transmission.
Charlie Stephens |
04-17-2018, 11:06 AM | #3 |
thanks, I was going to use a pinto 2.0, but it ain't the same as a banger, but at 79 I need to go to a automatic in current project.
04-17-2018, 11:40 AM | #4 |
Try going to the "Hot Rods and Customs Forum". It will take you to another site. Do some searches on that site. You will probably find more there on what you are trying to do. Here is a direct link to their forum section: https://www.jalopyjournal.com/forum/...ssage-board.5/
I have a '32 roadster with a Chevy II engine but its is hooked up to the early Ford transmission. I put it in 40 years ago because at that time I couldn't find any shop to do a good job rebuilding the original engine. If I was doing it today I would use an original engine with a little speed equipment. Charlie Stephens |
04-17-2018, 12:55 PM | #5 | |
If I was going to do that, I'd use the 2.3 or 2.5 which are bored and stroked versions of the 2.0 - higher HP and potential for upgrading to even more. I think a C4 will fit them - if not, I'm sure adapters are available. |
04-17-2018, 01:29 PM | #6 | |
04-17-2018, 02:25 PM | #7 |
If you do use a Pinto engine, just use a stock Model A muffler, and it will sound almost the same as a Model A engine.
04-17-2018, 03:53 PM | #8 |
Can't help you with a C-4, but check Bendtsen's for a GM 700R4 adaptor (among others). I bet that 4 speed O/D auto would work pretty nice.
http://www.transmissionadapters.com/Model%20A.htm |
04-17-2018, 04:28 PM | #9 |
I had a '31 with a 2000 pinto mated to a stock A tranny and muffler. Not a good combo because the pinto rev's too high for easy shifting without snychromesh. The prior owner/ installer should have used the pinto manual or automatic. Now someone else has that car.
04-19-2018, 10:30 PM | #10 |
I have a Chev 11 in my wife's Vicky And the Chev TH350 has the same bolt pattern as the Chevv with a small mod to the center cross member for clearance of the TH350
04-19-2018, 10:37 PM | #11 |
04-20-2018, 08:27 AM | #12 |
We used an A4LD out of a Ford Ranger Pick Up, has an overdrive and is working really well for us.
04-20-2018, 10:52 AM | #13 |
04-20-2018, 11:45 AM | #14 |
I would stay with the Model A engine, the others do not have much torque. However, I do have a 180 CID Chevy commercial engine that I would willingly part with. It is like a Chevy-2 but with a 4" bore, and more torque.
04-21-2018, 07:57 AM | #15 |
check on how much hp it takes to run the c-4 . ive seen the in hopped up bangers & they seem to work very well .
V4f |
04-21-2018, 09:10 AM | #16 |
04-21-2018, 09:10 PM | #17 | |
They don't show this particular adapter on their website, but lots of adapters for chevy transmissions. They do say "ask for what you want".
04-21-2018, 10:32 PM | #18 |
With all the adapters he has listed, I doubt he has much time to piddle around with a website. Best to give him a call and ask.
04-21-2018, 10:48 PM | #19 |
04-23-2018, 12:23 PM | #20 | |
I contacted the guys at transmissionadapters.com
