08-29-2017, 09:46 PM | #1 |
thermostats
Does an eV-8 require two thermostats?
08-29-2017, 09:51 PM | #2 |
Re: thermostats
Yep, there are two totally separate cooling systems except for internal to the radiator.
08-29-2017, 09:51 PM | #3 |
Re: thermostats
Yes sir. One for each cylinder bank.
Henry |
08-29-2017, 11:08 PM | #4 |
Re: thermostats
And each side needs a 170 degree thermostat made for a subaru. Put them in last week and I have never seen such fast warm-up and steady temps. The napa part # is in my shop.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
08-30-2017, 07:00 AM | #5 |
Re: thermostats
Would you post the napa part # when yiu get it? Thanks
08-30-2017, 07:06 AM | #6 |
Re: thermostats
If it aint broke, don't fix it! |
08-30-2017, 07:37 AM | #7 |
Re: thermostats
Balkamp brand from Napa. Part # 111. And made in USA of all places.
08-30-2017, 08:02 AM | #8 |
Re: thermostats
I have a set in mine as well . Got them @ Pep Boys .
08-30-2017, 01:25 PM | #9 |
Re: thermostats
Can't seem to find it on the NAPA site. Can someone post a picture?....
08-30-2017, 01:51 PM | #10 |
Re: thermostats
08-30-2017, 02:11 PM | #11 | |
Re: thermostats
'52 F-1, EAB flathead |
08-30-2017, 02:29 PM | #12 |
Re: thermostats
Thanks, guys....I see that the one pictured on the NAPA site has a rubber grommet around its circumference where as the one on eBay does not....
08-30-2017, 04:34 PM | #13 |
Re: thermostats
Thanks guys. MY '39 Peekup had only the right on. No wonder it always wanted to turn left!
08-30-2017, 06:56 PM | #14 | |
Re: thermostats
This is the best thermostat that I have found for year 'round, all temperature, all altitude use: the Stant 14157. The one I used I bought from O'Reilly as their part # 2962 that was in a Murray box # 4157 but it's the same as the NAPA # THM 111 and the Stant # 14157. All the same stat manufactured by the same manufacturer for a 1990 Subaru Justy.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
08-30-2017, 10:20 PM | #15 |
Re: thermostats
One of the many reasons I love the net as it pertains to the auto world. Who'd a thunk it? Subaru stats in a flathead v8..... My steel pipes pretty much meet against the outlets on the heads keeping the thermostats from rising up. My napa only had about 8" piece of hose so I cut it into four short pieces. And Henry, I love the look of your engine compartment and some may say you need to upgrade your wires etc., but as my physics teacher used to say..." The proof of the pudding is in the eating".
08-31-2017, 03:59 AM | #16 |
Re: thermostats
Thanks. Where do the safety wires go: drilled holes in the head?
08-31-2017, 04:33 AM | #17 |
Re: thermostats
08-31-2017, 05:37 AM | #18 |
Re: thermostats
Ah: thanks.
08-31-2017, 09:08 AM | #19 |
Re: thermostats
Clem,
I was able to put stats on my 45 truck without the Henry wire system. I got Stant stats from one of the suppliers. For my 39, I am trying Bob Shewman's stats that go up in the top hoses. All have worked well so far, although the passenger side cylinder bank on my 45 truck warms up pretty high before cooling down, even with new stats, so I am not sure what is up with that. |
08-31-2017, 10:25 AM | #20 |
Re: thermostats
Thanks. I have some new ones coming from NAPA. The old ones were well down in the hose and sideways.
