04-21-2016, 09:18 PM | #1 |
1937 tudor sedan body to frame bolt finish
Can someone tell me if the body to frame bolt heads are painted black like the body, or did Ford place the body on after it was painted. Thanks Bruce
04-21-2016, 09:41 PM | #2 |
Re: 1937 tudor sedan body to frame bolt finish
Pretty sure the bodies were painted before they were attached to the frames. It would have been a little difficult afterwards.
05-02-2016, 08:37 PM | #3 |
Thanks JSeery.
05-03-2016, 08:02 AM | #4 |
Body was dropped after painting.
05-03-2016, 10:37 AM | #5 |
Contact Roy Nacewicz, www.fordbolts.com for the bolts you are looking for. He has the complete set in what Ford called S-2 finish.
05-03-2016, 10:47 PM | #6 |
