Old 07-09-2015, 08:03 PM   #1
31pickup650
31pickup650's Avatar
Default 1931 Pickup Journal
Howdy. This is my grandpa's 1931 Model A pickup:
It was sitting in his driveway for quite a while and he wasn't using it. Now that I have a place of my own, the truck joined me here in Ohio (I am originally from California). I shipped it out here with Intercity Lines and would recommend them. They did a great job. Here it is coming off the truck:
It ran a couple years ago, but didn't by the time we shipped it out here so I had to push it into my garage. For barely weighing a ton, it sure felt heavy!
I figured out it wasn't getting any spark and replaced the wire leading from the terminal box to the generator. The coating had worn off and it was grounding itself. After that, it would chug, but wouldn't run when I tried starting it. I cleaned out the carburetor and that did the trick. It still a bit rough. The idle is not the best, but it seems to be running really lean. When i pull the choke in a little bit when its running and warm, it smooths right out. The plugs were all covered in carbon and one had some oil on it. I am replacing those and the gasket between the carburetor and the manifold since that is currently missing and probably causing the lean air/fuel mixture.
I gave it a quick test drive up the driveway:
https://www.dropbox.com/s/n79ezto8jv...%20pm.mp4?dl=0
I might need some help getting the carburetor settings right. I don't have much experience tuning those.
31pickup650 is offline   Reply With Quote
Old 07-09-2015, 09:58 PM   #2
Gary WA
Gary WA's Avatar
Default Re: 1931 Pickup Journal
Very nice to acquire a great family vehicle! Clean it up and enjoy it. Lots of help here if needed or your area for club members go to www.mafca.com and look under chapters in your state.
www.whidbeymodelaclub.com
Old 07-09-2015, 11:27 PM   #3
Brentwood Bob
You did the truck a big favor by getting it to run again, now let it return the favor.
Bob
Brentwood Bob is offline   Reply With Quote
Old 07-10-2015, 12:00 AM   #4
james hitchcock
james hitchcock's Avatar
Very nice.
james hitchcock is offline   Reply With Quote
Old 07-10-2015, 12:41 PM   #5
ddweave
ddweave's Avatar
I can't tell for sure from the photos. Does your truck have an all-metal top, or is it fabric in the middle? I ask because I have also have a '31 wide bed pickup - with a soft top.
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 07-10-2015, 02:13 PM   #6
Pmsqrd
Pmsqrd's Avatar
Consider restoring only the mechanicals and wiring. Leave the exterior just the way it is. The patina looks great.
Pmsqrd is offline   Reply With Quote
Old 07-10-2015, 04:09 PM   #7
CarlG
CarlG's Avatar
Originally Posted by ddweave View Post
...I have a '31 wide bed pickup - with a soft top.
Henry made them a dozen(or more) different ways. Mine has the steel top, but has the narrow bed.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-10-2015, 05:52 PM   #8
31pickup650
It has a hard top.
Old 07-10-2015, 05:53 PM   #9
31pickup650
That is my current plan. Clean off a bit of the dirt on windows and such, but not much more than that.
Old 07-10-2015, 06:14 PM   #10
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Nice truck and it is nice that it is staying in the family.
Good to see it back on the road, again.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 07-10-2015, 06:22 PM   #11
Fullraceflathead
Fullraceflathead's Avatar
Nice looking Truck. Nice to have it in the Family and it looks complete.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 07-10-2015, 06:24 PM   #12
31pickup650,
What is your name?
You should put a picture of your truck on your avatar.
I finally got around to doing it myself.
to do so:
click on "private messages".
Then over on the left, click on "edit avatar".
Regard, Neil
Old 07-10-2015, 09:10 PM   #13
31pickup650
Thumbs up Re: 1931 Pickup Journal
Originally Posted by Neil Mylar LakewoodCA View Post
31pickup650,
What is your name?
to do so:
Regard, Neil
My name is Noah. I updated my avatar, so now I have a "face."
-Noah
1931 Model A Pickup
My Model A : http://www.fordbarn.com/forum/showthread.php?t=173024
Old 07-12-2015, 10:45 AM   #14
31pickup650
I installed the carburetor to intake manifold gasket and new spark plugs today. This is what the plugs looked like:
I cleaned them off a couple days ago, but decided to replace them to see if that helped at all. Between the new plugs and the gasket, I think it is definitely running smoother. Not as smooth as I'd like, but smoother. I took a video of it idling. It sounds like I am getting a misfire maybe every once in a while. Any ideas? Here's a link to a quick video:
https://www.dropbox.com/s/2jptj7fnqm..._7368.MOV?dl=0
I also replaced the fan belt while I was at it. As you can see, it was definitely worn out and I didn't want to risk taking even a quick drive and having it break.
Next steps will be to install the seat belts I ordered and to get the spare engine up on a stand so I can try to get it to turn over.
-Noah
1931 Model A Pickup
Old 07-12-2015, 10:57 AM   #15
mshmodela
mshmodela's Avatar
Noah,
What kind of plugs are those? TT10s?
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-12-2015, 10:59 AM   #16
31pickup650
Originally Posted by mshmodela View Post
Noah,
Yep.
-Noah
1931 Model A Pickup
Old 07-12-2015, 11:05 AM   #17
mshmodela
mshmodela's Avatar
If you're head is original (compression) I found those to be too cold of a plug. If you drive on longer trips they'll likely do fine....
http://www.fordbarn.com/forum/showthread.php?t=6458
I've tried W18 and W16Y...
Also, FWIW, Summit Racing has both for about the best prices..
-Mike
Cleveland, Ohio
Old 07-12-2015, 11:15 AM   #18
1955cj5
1955cj5's Avatar
I like it,and I like your plan to more or less leave it as is...they are only original once....
I haven't even dusted mine after it came out of the barn...interior clean-up, and mechanical repairs, mostly brakes so far.......
Randy
1955cj5 is offline   Reply With Quote
Old 07-12-2015, 11:16 AM   #19
31pickup650
Thanks. I will give maybe a step or two hotter a try later on if these get fouled up or I can't get it running smoother. I work only about 10 minutes from Summit. A bit TOO convenient if you ask me...
-Noah
1931 Model A Pickup
Old 07-12-2015, 03:55 PM   #20
1931 flamingo
1931 flamingo's Avatar
Try putting some Marvel Mystery Oil in the gas. I usually dump 3-4 ounces in when I add gas, usually about 6 gals just to bring it above 1/2. Won't hurt anything and may help free up a sticky valve(s). FWIW
Paul in CT
