03-23-2015, 06:07 PM | #1 |
Rebuild or Not!!
Member of the club had a noise! Found It!!!! Pinion Bearing, you think!
www.whidbeymodelaclub.com |
03-23-2015, 06:10 PM | #2 |
Re: Rebuild or Not!!
sure rebuld why not
did it lose a pinion bearing? |
03-23-2015, 06:21 PM | #3 |
03-23-2015, 06:23 PM | #4 |
Slap it together with three handfuls of sawdust - that will fix it.
Joe K
Shudda kept the horse. |
03-23-2015, 06:33 PM | #5 |
I know that noise ; growl, growl, growl, chirp chirp, BANG.
03-23-2015, 08:39 PM | #6 |
Good luck! Larry |
03-24-2015, 11:18 AM | #7 |
When I first got my 1929, although the transmission was noisy overall, you could barely hear when I put it into second gear. When I pulled the trans and took it apart, I had the same pile of various bearing rollers as well. I can't even figure out how it worked...
03-24-2015, 11:23 AM | #8 |
Just dump a quart of Lucas in...... You won't hear a thing!
03-24-2015, 11:44 AM | #9 |
Wow what a mess! I had a bad ring and pinion (broken teeth) but it didn't look that bad.
John from Kapowsin T&A Guy |
03-24-2015, 11:57 AM | #10 |
Looks like the ring gear is ok, just weld that one tooth up and grind her down!
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
