04-11-2024, 08:56 PM | #1 |
Oil Pressure Sender... 6v & 12v
My '51 Tudor project continues, converted to 12v neg. ground but voltage reducer to fuel, temp, and oil pressure gauges. I have an under dash gauge cluster for 12v temp and oil pressure, both are electric, can the electric oil pressure sender share the same sender? Thanks guys
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
04-11-2024, 09:44 PM | #2 |
Re: Oil Pressure Sender... 6v & 12v
The senders don’t care if it’s 6 or 12 volt. However the original senders don’t work with aftermarket gauges.
04-11-2024, 09:52 PM | #3 |
04-12-2024, 02:43 AM | #4 |
Senders work on resistance, so 12v or 6v doesn't matter. But the gauge and sender resistance must match (aftermarket vs factory). You can make your stock gauges work with a different engine if needed, I would run the stock setup.
04-12-2024, 07:13 AM | #5 | |
I'm not understanding your post. You put a voltage converter in? The under dash gauges are they after market? Like others have said, you can't mix non-matching senders with gauges unless your extremely lucky, then buy a power ball ticket the chances are they same you hit the jack pot. |
04-12-2024, 07:40 AM | #6 |
04-12-2024, 02:54 PM | #7 |
Thanks for the responses guys. I figured this was a no go. I'll have to decide which oil pressure gauge I want to rely on, the original or the under dash Stewart Warner for which I do have a matching sender. And thanks Denny, I should have remembered the "King-Seeley" system.
04-12-2024, 03:03 PM | #8 |
Put a T in the engine and mount both senders then all the gauges would be operational, although a mechanical aftermarket would be preferable.
Thread Tools | |
Display Modes | |
