11-16-2023, 01:25 AM | #1 |
Southern Ca banger machine shop?
Hi, my model b diamond block took a dump, threw a rod bearing and smoked the front main babbit bearing.
I left HnH a VM but does anyone know of other machine shops in southern CA that can replace the babbits for insert bearings on my block’s mains? Thank you. |
11-16-2023, 09:39 AM | #2 |
Re: Southern Ca banger machine shop?
Dave at BMS Machine Services in San Bernardino rebuilt the 8ba in my '39 p/u but I don't know if he can do what you need. If not he might know who does. He builds everything from stockers to LSR engines and knows his stuff (and a heck of a nice guy as well).
Be prepared to wait if he can do the job but it will be worth it, IMO (909) 799-7770 Another thought is Johnson's Automotive Machine in Yucaipa, CA. He has a good rep for flatheads. He recently did all the machine work for an 8ba with a Merc crank for a roadster p/u belonging to a guy I have coffee with on Saturday mornings. One man shop but quality work. (909) 797-2063
Making the simple complicated for over 30 years. |
11-16-2023, 09:46 AM | #3 | |
11-16-2023, 12:07 PM | #4 |
So that's why I haven't seen it around ------ I can't directly help you, but if you can make some contact with the Santa Barbara Model A club, they may know of a shop up that way that can help you. Try looking for Ron Ryker.
11-16-2023, 12:18 PM | #5 |
Try Ed Tolman at [email protected]. He owns a machine shop in Pomona, and is a Model A guy that started rebuilding A/B engines a couple of years ago.
11-16-2023, 02:50 PM | #6 |
11-16-2023, 03:17 PM | #7 |
I highly recommend Joe Sivils at Turlock Machine. It's a 5 hour drive from Ventura but you will be extremely happy that you made the drive. Have Joe convert your bearings to inserts and pressurize the oil.
I refuse to do business with H&H. As one of my club members said, " What good is their warranty if you have to keep using it". Turlock Machine 209 495 1689
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
11-17-2023, 12:32 AM | #8 |
Thanks to all for your replies. I drive to SF often for work so taking an engine along is no sweat. I’ll call them all. Thanks guys. J.
11-17-2023, 11:37 AM | #9 |
Joe Sivils does good work, but he is SLOW!!! Usually he takes over a year to do an engine. He recently spent time in the hospital, not sure how he's doing now?
11-17-2023, 12:40 PM | #10 |
You might also consider finding a rebuilt motor rather than rebuilding your current one
Sammy at model a parts in Arizona might be worth investigating I have done rapid disassembly repairs and sometimes it just isn’t worth it J
As Carroll Smith wrote; All Failures are Human in Origin. |
11-18-2023, 07:50 PM | #11 |
11-21-2023, 12:36 PM | #12 |
Syncro99, the repair shop in Kelowna , is K&S Machine , the owner is Keith Korecki. He did the insert work etc on my engine about 20 years ago ,no issues. He has a very busy shop ,does a lot of drag engines. He also prepared several engines for a local club for their model a tour to Alaska,again good results.
Their phone number for any one interested is 250-807-2204. Don’t forget your dollar goes a long way in Canada, saving between 25-30% . Don S |
11-21-2023, 01:07 PM | #13 | |
It’s a great road trip to British Columbia (which I have made several times) if you have time to go. If I told my wife I needed to take my engine to BC she would say “when do we leave”. David Serrano |
11-21-2023, 04:26 PM | #14 |
My company sent me to Canada in the late 70s to fix some equipment. It was a real hassle taking parts and tools. They inventoried everything and said I had to bring it all back with me or pay import on what stayed in Canada.
I beat em - they couldn't tell new circuit boards I took in from the junk ones I took out. |
11-21-2023, 10:43 PM | #15 |
Hi Team, I called everyone you all offered. some did not do main bearings and many never called me back. I was able to find someone to do the work by network through the MAFCA so I’m all set to get the engine fixed, unless more bad news is received. Thank you all and keep your fingers crossed for my banger, best of luck with your cars and projects!
11-21-2023, 10:54 PM | #16 | |
11-22-2023, 12:43 AM | #17 | |
David Serrano |
11-26-2023, 10:33 PM | #18 |
Joe had my engine done in a couple months.
11-27-2023, 03:12 PM | #19 |
Hi, I’m back to the drawing board. The shop I was going to use cannot do Model B engines, only As, so I’m searching again…
My list - BMS doesn’t do main bearings - Johnson’s auto - left 2 VMs, no call back yet - HH - 2VMs, no call back yet - Turlock machine - spoke with Joe and I don’t think I can afford his work . - I will continue to network through the Model A clubs locally. My dilemma:: I have 7 Flathead blocks at the machine shop now, if one comes back good, I’m tempted to build one for my roadster but really don’t want to scrap the Model B. I love my Banger and I’m doing everything possible to keep it because it is in excellent condition (minus the rabbit bearings) but the cost to fix it may be close to a V8 build…. Thanks for your help!!! Keep sending ideas, J |
11-27-2023, 04:36 PM | #20 | |
I totally understand your dilemma, but you are not alone. The problem is the costs to own/repair/restore one of these cars is not affordable for many. From my perspective, the problem on the other side is the costs to own & operate a machine shop with decent quality equipment is absolutely crazy now. And, ...the customer's expectations in these times are so high that a shop owner does not dare try to use an inferior (i.e.: inaccurate) machine to do machine work because the costs of labor, and potential for re-do's from poor machine work easily make doing them unprofitable unless they charge accordingly. Then factor in tooling costs & supplies whose prices have escalated over 50% in the past 3 years, plus the costs of utilities, insurance, and employee labor, -and I think you quickly find the day of the $3,500 engine rebuild are behind us. |
Thread Tools | |
Display Modes | |
