10-25-2023, 04:19 PM | #1 |
1940 Ford Standard Coupe
City:
Western
State:
WI
Price:
$30,000
Cars are located in Wisconsin. My friends wife whose husband passed away this past winter has decided to sell his car. He has owned the 1940 Ford coupe since the early 70s. Asking price is $30,000. Serious inquiries only. Contact me and I can put you in touch with the owner. 1940 Ford Standard Coupe Total frame off New wiring New paint New interior (LaBaron Bonney) Drive train gone through New brakes PARTIAL LIST OF PARTS FOR 1940 FORD RESTORATION 4 new tires (not driven since tires were put on) Left & right side flathead V8 water pump, water pump to block mtg hardware kit, body frame bolt set, 2 copper O-ring gaskets, master cylinder connector, master cylinder outlet bolt, Engine enamel Ford green Rubber pedal, single line clamps, stone guard Brake lines, fuel pump block off Many brake related parts Flathead universal spark plug wires kit Rubber brake line hose set-20 calipers, ignition resistor, universal power/manual master cylinder, 1 inch bore, brake proportioning valve Brake parts, Ford Flathead spark plug wire looms, stainless steel Disc brake residual valves Brake parts 40 Ford Deluxe Headlight Rims AutoMeter antique beige Air-core fuel level gauge, fuel level sender, throttle shift arm, throttle cable Hot Rod Turn Signal Steering Column Floor Shift pectre Chevy Small block SBC V8 fuel pump block mounting plate w/bolts chrome Pertronix 45001 Flame-thrower II coil 45,000 Volt 0.6 ohm Chrome (ignition coils) Wheel, smoothie, steel, chrome/bare, 14 x 6. 5 x 4/50/4,75 inn Bolt Circle 4.00 backspace (2) Steering wheel Universal Billet 3 1/8 x 2 Brake/clutch pedal custom Hot Rod Rat Rod GM Brake Master Cylinder 1 1/8 Bore 3/8 Ports Dual Corvette Chrome Fla . . . . 16 pc. 3/16 stainless steel brake line clamps clips and screws, street Rod/ . . . . Fuel level sender sending unit, GM type, 0-90 ohms, 6-24 adjustable Bosch 15910 Air Fuel Ratio Sensor Inner Apron Panels Mustang II 1940 car Hood Bumper Kit, Gas Neck Hose 1940 Ford, Front Fender Inner Apron Bumpers, Chrome handles, cranks & knobs with stainless steel Escutcheons Ash Tray Retainers -1940, Ash Tray 1940 Gas pedal rod firewall to carb, radio hole cover, choke throttle firewall grommet, starter button-sand, dash knob set, C & T cable grommet (pair), choke & throttle rods, gear shift knob, fan belt with molded Ford SCR, headlight switch with wires, cigar element * well 12 volt Trunk Seal hollow core bonded cowl vent gasket, back window seal 4 wheels, smoothie, steel, chrome/bare; 4 Center cap stainless steel, polished, Snap-in, Dome style 1940 standard V8 design |
Thread Tools | |
Display Modes | |
