06-11-2023, 05:29 PM | #1 |
3X Spark Plugs
I have ten of the repro Champion 3X plugs with the flat top on the number "3." These should have an upper and lower copper seal in the interior, which in this case are quite worn. Are these seals even available commercially, or do the seals provide little value in the firing of the plugs?
06-11-2023, 07:16 PM | #2 |
Re: 3X Spark Plugs
http://modelabasics.com/home.htm thanks to supplier of site. Go to spark plugs they act as a seal.
www.whidbeymodelaclub.com |
06-11-2023, 07:27 PM | #3 |
Re: 3X Spark Plugs
I saw this when I was searching for info on the 3X plus. A good write-up. Maybe a thin-enough sheet of copper can be located so that one can make their own seals.
06-13-2023, 09:12 AM | #4 |
Re: 3X Spark Plugs
If you still have the original copper sealing rings you could heat them up and quench them in water to anneal the copper then they're reusable as the copper will be soft and pliable again and seal like it originally did.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
06-13-2023, 11:12 AM | #5 |
Re: 3X Spark Plugs
Regards Bill |
Thread Tools | |
Display Modes | |
