08-09-2022, 05:10 AM | #1 |
Burtz Block
Hey all
As you well know I’m new to this group I have been researching options for engine rebuilding and stumbled across Burtz Blocks This seems like a FANTASTIC solution to a dwindling supply of rebuildable cores. Finding a machine shop that can actually pour Babbitt is few and far between With a counterbalanced crankshaft 5 main bearings and strong rods this should be a bullet proof combination. I have always read that compression ratios above 5.5 tend to “flatten” bearings with a “modern” crank and bearings could the compression be bumped up? Maybe to 8.5? The end result would be much cooler running engines and more usable power My car as it is runs very well but I’m thinking about my cousins car. He has a 31 roadster that my late uncle was dissembling but he passed suddenly leaving an unfinished project. His core is in need of a full rebuild and I’m only thinking Thank you all for listening and I look forward to your replies Dave |
08-09-2022, 05:27 AM | #2 |
Re: Burtz Block
My (rebuilt) engine runs fine, but when it comes time to rebuild it, I plan to consider a Burtz block. It’s not that much more expensive than a quality rebuild, and you get a new engine out of the mix.
Search for Burtz block on this forum. You’ll find a treasure trove of facts and opinion. Sent from my iPhone using Tapatalk |
08-09-2022, 05:52 AM | #3 |
Re: Burtz Block
Compression has no effect on babbit. Babbit was used effectively on diesel engines at 19 to 1 compression ratio. Improperly maintained/adjusted rod and main bearings cause babbit failure.
08-09-2022, 06:40 AM | #4 | |
Re: Burtz Block
Dave, I have been around this hobby for over 60 years, ...and professionally since 1997. A couple of things I have noticed during the last decade or so, is the amount of false, -or misleading information that today's hobbyists tend to pass around about Model-As. (Likely happens in other hobbies too with more prevalence since social media has become popular but I see it very prevalent in this hobby.) I will address two of your opinions stated above. First, while I do not know yours or your cousin's age, I can say with certainty that there are more qualified craftsmen casting good quality bearings in Model-A engines than what was available to the hobbyist some 30 years ago. The quality (-and availability) of good materials used to cast bearings has never been better now than what we had available in the past 50 years. The quality of tooling necessary to do this craft that is found in these shops today is also better overall than it has been in decades. I don't know your cousin's location, but I feel comfortable that he likely has a shop nearby that can more than capably rebuild his engine. Your second comment about cast (-babbitt) bearings being flattened in engines using over 5½:1 compression falls into the category of 'People will only believe what seems believable to them!' and I am unsure where your myth came from. For many years prior to insert bearing shell conversions being done on Model-A engine blocks, Larry Brumfield manufactured a cylinder head that had a 5.9 compression ratio factored at standard bore. He also manufactured a Super Brumfield with ratios exceeding 7:1. Many other head manufacturers during the 1940s - 1970s manufactured heads for bangers that often exceeded 8:1 that made great power and the cast bearings lived with those ratios. Heck, many early trucks and marine diesel engines used babbitt bearings and had compression ratios well past 15:1 compression (-nearly 3X your 5.5 number) and these engines provided many, many hours of reliable service. Therefore, it is my opinion that your myth has no merit and was likely started by someone who was stretching the truth to promote insert bearing conversions. Now with this said, Terry Burtz's engine is a nice piece that does have a place in today's market. I would agree that his combination should be very bulletproof with the internal components that he offers in his package, however with that said, the same can likely be said with using an original engine block as the foundation and choosing a counterweighted (i.e.: SCAT) crankshaft and a few other aftermarket components too. My point is since you are 'new', please keep an open mind as you do your research to understand we live in a society today where people often place inaccurate or misleading information onto the web for unknowing people to read and thus assume it must be accurate simply because they read it on their computer. |
08-09-2022, 07:26 AM | #5 |
Re: Burtz Block
Got it!
How do I find a machine shop in the Cleveland Ohio area that can handle this? I have built several performance engines and the shops I use for that work really don’t know where to send me? I never considered “other” engines and Babbitt bearings as a comparison! That makes perfect sense! I do realize what you are saying with the internet as well. So many are naysayers and regurgitate disinformation that people like myself start to “believe” it! Thank you for everything! Dave |
08-09-2022, 10:47 AM | #6 |
Re: Burtz Block
08-09-2022, 11:14 AM | #7 | |
Re: Burtz Block
Dave, The weak link in a Model A engine is not the Babbitt. In-line diesel engines using Babbitt have very stiff crankshafts and main bearings between every cylinder. The weak link in a Model A engine is the flexible crankshaft with 3, 1.625-inch diameter main bearings and 4, 1.500-inch diameter connecting rod bearings. Crankshaft flexing wallows out the soft Babbitt and the flexing becomes more severe with higher compression and RPM. Inserts help to limit the amount of wallowing because the soft Babbitt layer is much thinner than a poured bearing. A SCAT crankshaft with the same number of small journals is just as flexible as a stock Model A crankshaft and will not fix the inherent design problems. Ford recognized the inherent design problems in the Model A engine and the Model B engine had larger crankshaft bearing journals. There is a builder in CA that is hoping to get 400 HP out of the new engine with a turbocharger, electronic fuel injection, and electronic ignition. |
08-09-2022, 11:24 AM | #8 | |
Re: Burtz Block
MrBruce, "(I had one but just didn't have the shop to do what was needed)". Please tell us more about "what was needed". The "new engine" parts are ready to assemble after deburring and cleaning and no machine work is needed. |
08-09-2022, 08:26 PM | #9 |
Re: Burtz Block
Before the Burtz engine was available, I used a rebuilt engine to tow a heavy camper many tens of thousands of miles but after the most recent trip, it was showing "tired" signs. To me, one of the new engines was a no brainer with its stiffer crank shaft, more main bearings, full pressure lubrication and new metal - just as I would have written on my wish list.
The rebuilt engine has a Burlington crank shaft and new rods. All run on inserts. The middle main bearing is pressure fed at 25psi. It has a modified cam - no more lift than the original but more duration and began life with a 5.5:1 head and downdraught carburettor. The compression now is 105-110 psi which is near enough, 7:1 after the head has been "flattened" a few times. As good as that engine has been, I'm expecting the new one to be a lot better. I realise probably none of you guys will put your engine through such torture but IMO, the way mine has preformed, an engine rebuilt like it would last a long time in a solo car. BTW, we cruise at 50 mph for many hours at a time day in, day out for weeks with the camper behind. It weighs about 900 kg (2,000 lb) An average trip is about 8,000 miles. I wouldn't hesitate (subject to the approval of the banker) to buy another Burtz unit. Mine was one of the first and no "extras" other than a flywheel were available with it then. (Engine number 15)
08-10-2022, 05:08 AM | #10 |
Re: Burtz Block
Synchro
What kind of “power” do you anticipate? I’m curious more than anything The more I look at this the more I like it! Thank you for sharing Dave |
08-10-2022, 06:20 AM | #11 | |
Re: Burtz Block
08-10-2022, 06:22 AM | #12 |
Re: Burtz Block
The Burtz engine is basally and assembly project. You have to clean up the engine and do some deburring, but the rest is just assembling the parts. If you have any experience in engine rebuilding it is actually easy. You have to keep your shop and the parts clean, like any engine rebuilding. It can actually save you tons of money and the engine will perform well for many miles, well beyond your lifetime. Plus you can hop it up as needed for your driving requirements. Terry posts very good assembly instructions on his site.
08-10-2022, 06:31 AM | #13 | |
Re: Burtz Block
I estimate I'm getting about 70 hp out of that 3 main bearing engine and considering what I have done with it, I can't complain.
08-10-2022, 06:40 AM | #14 | |
Re: Burtz Block
Once I reach about 55 mph, things are coming together pretty well. Economy is excellent and still plenty of "let's get going" from the engine.
08-10-2022, 07:09 AM | #15 | |
Re: Burtz Block
Ok. Maybe others will chime in, but all of the 7:1 heads I have messed with have a lowered roof in the combustion chamber simply because you cannot take enough off of a 5.5 head without getting piston interference. If the 'squish' area over the piston is minimal, it is my experience this will cause detonation issues where setting for optimum timing is a struggle as you have suggested. As I'm sure you, and most others will agree, using a compression gauge to determine the ratio is rarely accurate. To confirm this, think about when you are taking the reading. Most will crank the engine over a minimum of 4-5 times while obtaining the reading, and each time the piston makes a cycle, the gauge reading gets higher and higher. The first time the piston comes up is more likely the closest correct reading on the gauge. The only accurate way for most people to determine a C/R is to CC the chamber and calculate gasket areas, etc. |
08-10-2022, 11:59 AM | #16 |
Re: Burtz Block
I want to make one comment about Babbett bearings. The insert bearings consist of a steel shell with some copper and then Babbett metal added. The Babbett metal is what is actually against the journal (the oil film is actually between the Babbett and the journal).
08-10-2022, 12:36 PM | #17 | |
Re: Burtz Block
So allow me ask a question regarding thicknesses, ....would you rather buy a new set of tires that has 10/32" of tread depth, -or tires with 3/32" of tread depth?? It seems like someone would get 3X more mileage when they start with the 10/32" depth tires. So if the same thought was applied to Model-A engine bearings, wouldn't someone get 3X more longevity out of a babbitted engine over a inserted engine if the same quality of bearing materials was used, and all mechanical parts were of equal specification and condition?? |
08-10-2022, 12:58 PM | #18 |
Re: Burtz Block
Why would you own an A, drive it, fake the engine ?
You don’t own a Model A ... it owns you ! |
08-10-2022, 01:06 PM | #19 |
Re: Burtz Block
Provided the babbit bearing is properly maintained the extra thickness is beneficial
Another observation about babbit vs insert bearings.. When a babbit bearing fails it rarely destroys the crankshaft journal it bore. When an insert bearing fails it invariably destroys the borne journal. |
08-10-2022, 03:29 PM | #20 | |
Re: Burtz Block
That is why High performance and race engines use Tri-metal bearings. Tri-metal bearings have a steel back , copper underlay to support the thin layer of Tin/Babbitt. The copper underlay is not nearly as compressable as Babbitt and as a result less fatigue and longer bearing life. Bill PS Read up on Clevite 77 bearings. |
Thread Tools | |
Display Modes | |
