02-20-2022, 03:07 PM | #1 |
8BA distributor questions
I just cleaned up this old dog of a distributor for the '53 F100 project. Let's start with the tag...Why are some red and others black? To the left side of the FoMoCo emblem, this one is stamped 2H...What does that decipher to? Holley manufacturer? I can not make out the prefix to the 12127 number printed to the right of the FoMoCo emblem...to badly worn. On the side of the cast iron housing "7RA 12131-C" is cast into the housing. Does the 7RA make it a 1949-1950 distributor? On the other side of the housing is another mark that is not legible and a 4 cast in the housing. I hope the pictures help? I don't feel any side to side wear of the shaft in the housing. The lobes look like they are worn. When matching the distributor to the carburetor, what is actually being matched? The size of the carburetor venturi to the vacuum diaphragm on the distributor? As always...thank you in advance for the help.
02-20-2022, 10:15 PM | #2 |
Re: 8BA distributor questions
There may be a diference in tags based on wether the distributer has the extended shaft for the aluminum timing cover or the cast iron cover and whether or not the distributer is for a Ford or a Mercury engine.
The information on this Google search will help you discern differences. https://www.google.com/search?q=7ra+...client=gws-wiz |
02-20-2022, 10:16 PM | #3 | |
02-21-2022, 05:19 AM | #4 |
Here's what you need to know about 8BA distributors and timing covers. Obviously, the distributor should (and sometimes must) match the timing cover. I believe the extended shaft distributors are Mercury. Thanks to "V8 Bob" on the H.A.M.B.
02-22-2022, 11:58 AM | #5 |
Is the timing mark that raised bump that is noticeable on cover C in the first photo? Or is it the mark at about the 10 o'clock position above the shaft seal area? And I am going to guess the cover A is for the aluminum housing distributor with the different looking drive gear.
02-22-2022, 12:38 PM | #6 |
02-22-2022, 01:47 PM | #7 |
The 7RA casting number indicates it is an earlier (than '53) housing, but that doesn't identify the internals. Not really much difference between trucks from 48 - 53 other than the lengths already pointed out. Specs below.
'52 F-1, EAB flathead |
02-22-2022, 03:06 PM | #8 |
From my experience, it is very vague as to what tag is correct. I have 2 different 8RT engines that both have cast iron 7RA tagged distributors. More examples would be more accurate, but am thinking items were used up regardless of what manual said was on a particular engine by year.
I dig coal, which provides motivation for EVs. |
02-22-2022, 07:24 PM | #9 |
Holley likely didn't manufacture all the parts for the load-o-matic systems. Ford may have made them and possibly others as well.
02-22-2022, 07:41 PM | #10 |
In the first picture the factory literature states the '50-'53 F series trucks use 8ba-6059-c front cover 4. On the back side of my dist. is a number 4 cast in the housing. Which one of the covers is the number 4 cover? I looked at a slew of covers currently listed on ebay this afternoon. Noticed a few variations like in the other post pics. Thanks for the info from the factory lit. on tuning differences.
02-22-2022, 07:49 PM | #11 | |
02-23-2022, 01:10 PM | #12 | |
You can use any of covers B, C, D with your distributor (cast iron or aluminum).
Thread Tools | |
Display Modes | |
